Newton Message Pad
  • BenW
    • Jul 2022
    Newton Message Pad
    I'm a newbie on this forum.
    I have an original Newton Message pad and was wondering if I might damage it electronically if I power it up for too long. I powered it on for only about 1 minute just to see if it had any life left in it.
    Any idea how many capacitors should be replaced or other updates I should expect before it could become reliable?
  • rumpumpel1
    T490 error message 2203 Skip acknowledgement of an error message
    by rumpumpel1
    I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
    This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
    Is it possible to change the BIOS so that this message no longer has to be acknowledged?
    MTM 20N3S19L00
    system SN PF1X4JP8
    board SN L1HF171000X...
    01-19-2025, 03:32 PM
  • Prabuth
    always showing this message AC adapter = Unknown
    by Prabuth
    The customer gave me this for changing the old battery, and then I replaced the new battery. always showing this message. I changed many chargers and programmed the new BIOS as well. Does someone have any idea for this message?
    Yesterday, 01:26 AM
  • Scruit
    Does the Oak OTI067 have a splash screen / initialization message at bootup?
    by Scruit
    tl;dr ... Question: Does the Oak OTI067 have a splash screen / initialization message at bootup?
    More detail:
    Working on "Uncle Sherman", my Mitsubishi MP-3200 386 from 1988. Before I start up old computers I have a process where I disassemble, test for shorts, visually inspect, capture EPROM images etc.
    My T866II+ give me a "pins not detected" error on the EPROM from the Oak-based (OTI067 GPU but apparently a no-name card??) I assumed the EPROM was bad, ordered a replacement and figured I'd program a downloaded ROM image to it....
    04-17-2022, 06:03 AM
  • Francesc V.
    Technics SA-AX530 in protected mode. Overload message
    by Francesc V.
    I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
    I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
    I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
    (Pin 13 goes through...
    11-18-2024, 12:39 AM
  • tcpip
    IdeaPad 5 15ARE05 Possible BIOS message and doesnt boot
    by tcpip
    My Lenovo IdeaPad 5 15ARE05 only 2 years old shows this message when I start it:
    BIInializeLibrary failed oxc0000185
    then it doesnt boot and i have shutdown by holding the power button
    I did goodle but canot undertand what is wrong and where to start. I have reset bios and also upgraded to newer bios but it didnt make a difference.
    sometimes it boots to wondows but very often I it get the above message?
    03-19-2023, 10:18 AM
