IdeaPad 5 15ARE05 Possible BIOS message and doesnt boot
  • tcpip
    • Mar 2023
    My Lenovo IdeaPad 5 15ARE05 only 2 years old shows this message when I start it:
    BIInializeLibrary failed oxc0000185
    then it doesnt boot and i have shutdown by holding the power button
    I did goodle but canot undertand what is wrong and where to start. I have reset bios and also upgraded to newer bios but it didnt make a difference.
    sometimes it boots to wondows but very often I it get the above message?
  • dalek1967
    • Feb 2023
    • 14
    Re: IdeaPad 5 15ARE05 Possible BIOS message and doesnt boot
    I'm a Linux guy so I don't know much about windows. I did a little digging and it appears the error can have a few causes. The main one is a bad or corrupt file. That can be caused from a drive going bad, file system problem, a improper shutdown or just something went wrong somewhere and it got corrupted. The biggest thing is how to fix it. I found the video linked below. Since I don't use windows, I didn't watch it but I saw it mentioned in several places. Sometimes a video where you watch someone do something is easier to understand than reading text.
    https://www.youtube.com/watch?v=hxYYINOj9zc
    I also found this link that has some pretty good instructions, with links to other info as well. It may be a good plan B.
    https://www.lifewire.com/fix-error-c...000185-4691254
    When you get it fixed, I'd recommend running some sort of hard drive test or file system test, both may be a good idea. It may help make sure this doesn't pop up again.
    Hope that helps.
    • tcpip
      • Mar 2023
      In my case the error most likley is not related to windows or ssd.
      It is shown even before the booting process starts.
      Also the clock in the windows always become wrong even after I have tried update/disable automaic clock/change time server/reset window clock services.
      I wonder whether it could be due to an error in motherboard.?
      What else could i try?
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        better check the board cmos battery and test it voltage if its 3v its good but if its lower need to change it
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • q2v5
          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
          by q2v5
          Lenovo T480s
          Model 20L8-S3TE00
          Board ET481-U10
          Chip MX25L12873F
          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
          08-15-2024, 10:40 PM
        • jendkkd jeje
          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
          by jendkkd jeje
          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
          10-11-2024, 03:12 PM
        • Max029
          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
          by Max029
          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
          TY,
          08-18-2024, 08:28 PM
        • futadmytro
          Asus g713qm-es94 stuck on boot bios problem
          by futadmytro
          sn^M4NRKD02753616E
          MB- g533-6050a3250201-MB-A03
          Stuck on boot after ROG logo, did not enter to bios
          In flash bios , laprop boot but have video issue
          orig bios...
          06-25-2025, 08:07 AM
