Macbook Pro 2020 Touch Bar A2289 Ambient sensor and camera not working
  • mon2
    • Dec 2019
    • 13868
    Remove all power. Meter in diode mode. Red meter probe to ground, yes red. Black probe to point to test.
    Check the scl pin of the i2c / smbus lines for devices that are faulty. Repeat for sda pin measurement. Post each value.
    • nelusab
      • Aug 2022
      • 27
      • România
      Forgive me for delay, it was my daughter's birth day.
      Now the measurment results:
      FT CAMERA
      I2C_FTCAM_DSBL_SCL 0,591
      I2C_FTCAM_DSBL_SDA 0,583
      I2C_FTCAM_ISOL_SCL 0,550
      I2C_FTCAM_ISOL_SDA. 0,557
      I2C_FTCAM_SCL_R 0,439
      I2C_FTCAM_SDA_R. 0,440
      I2C_FTCAM_SCL 0,438
      I2C_FTCAM_SDA. 0,439
      ALS CAM
      I2C_ALS_SCL_R 0,243 / MEASURED ON LVDS CONNECTOR
      I2C_ALS_SDA_R. 0,242 / MEASURED ON LVDS CONNECTOR
      I2C_ALS_SCL_R 0,440. / MEASURED ON R5315 / Flex cable LVDS removed from board
      I2C_ALS_SDA_R. 0,441 / MEASURED ON R5316 / Flex cable LVDS removed from board
      • mon2
        • Dec 2019
        • 13868
        If you disconnect the ALS cable, what are the results? The diode values are different with and without this ALS cable connected to the logic board.
        What is the history of this machine? Just stopped working? Liquid damage?
        • nelusab
          • Aug 2022
          • 27
          • România
          I've checked again, the results measured on LVDS connector are not accurate , actualy they are the same with the results measured on board, for ALS CAM.
          • nelusab
            • Aug 2022
            • 27
            • România
            Also measured I2C_ALS_SCL. 0,439
            I2C_ALS_SDA. 0,439
            • mon2
              • Dec 2019
              • 13868
              These are good diode mode measurements for each. If practical, carefully measure the voltage to ground of these same lines. This is to confirm that the mandatory pull-up resistors are being pulled up to their logic '1' state when parked. Also note that the non-working camera / ALS / keyboard backlight will only be enabled when the LCD display lid is detected to be OPEN. This is my understanding. This open / close status is based on a hall effect sensor that operates between the trackpad and the display assembly. In the schematic will be a signal rail with the keyword 'LID' that will offer a '1' or '0' logic level based on the condition of the lid assembly. This signal should be reviewed. If the LID is considered to be closed, the above functions will disable.
              • nelusab
                • Aug 2022
                • 27
                • România
                #27
                Hi mon2, I'm back with the measurements you requested
                FT CAMERA
                I2C_FTCAM_DSBL_SCL 0,591 - 1,800 V
                I2C_FTCAM_DSBL_SDA 0,583 - 1,800 V
                I2C_FTCAM_ISOL_SCL 0,550 - 1,816 V
                I2C_FTCAM_ISOL_SDA. 0,557 - 1,816 V
                I2C_FTCAM_SCL_R 0,439 - 1,816 V
                I2C_FTCAM_SDA_R. 0,440 - 1,816 V
                I2C_FTCAM_SCL 0,438. - 1,816 V
                I2C_FTCAM_SDA. 0,439. - 1,816 V
                ALS CAM
                I2C_ALS_SCL_R 0,439. - 1,816 V
                I2C_ALS_SDA_R. 0,439. - 1,816 V
                Also measured :
                PP3V3_G3S. - 3,33 V
                SEP_CAM_DISABLE_DFF_L - 1,816 V
                PP5V_G3S_ALSCAM. - 5,14 V
                SMC_LID_LEFT. - 1,810 V
                SMC_LID_RIGHT - 0 V ????????
                IPD_LID_OPEN - 1,816 V
                The measurements where made with the board out from inclosure.
                It ssems there could be some issues with the right LID sensor, but could this affect ALS CAM?
                • nelusab
                  • Aug 2022
                  • 27
                  • România
                  #28
                  The board has only the left LID sensor, so the value for the right side is normal
                  • nelusab
                    • Aug 2022
                    • 27
                    • România
                    #29
                    What does mean DFF from SEP_CAM_DISABLE_DFF_L ?
                    If it means DEFAULT it sould be in Low state?
                    • mon2
                      • Dec 2019
                      • 13868
                      See attached. This signal is used by the multiplexer @ U8502.
                      If this signal is LOW then this state is considered to be true (denoted with the _L suffix in the netname label). That is, this is an 'active LOW' enable. When LOW (0 volts) then the camera is DISABLED and vice-versa.
                      What is the voltage to ground of this signal ?
                      Click image for larger version  Name:	mux_table.png Views:	0 Size:	43.5 KB ID:	3249637
                      • nelusab
                        • Aug 2022
                        • 27
                        • România
                        #31
                        In a privious post is mentioned
                        • mon2
                          • Dec 2019
                          • 13868
                          Appears to be dustgate:
                          https://www.forbes.com/sites/jaymcgr...-displays/amp/
                          • nelusab
                            • Aug 2022
                            • 27
                            • România
                            #33
                            The scrren works well, without any lines or glitches. I've dissasembled from the topcase and checked the flex cables on microscope. No noticeable damage, and as I said works well, I mean the graphic function.
                            The laptop had macos Catalina installed on it and all functions, including ALS cam, FT cam, KB backlight, where working. During an system upgrade something happened resulting in a kernel panic, so the upgrade process couldn't be finished, the laptop entered in a loop booting mode, the progrss bar riching half on its way and restarting.
                            So I performed a DFU revival, followed by a DFU restoration without succes. The DFU restora prcess works ok, but on the OS install process the same issue appeared.
                            I had to install SONOMA on an external SSD, booting from it and cloning the system on the internal SSD. Now the laptop is booting into SONOMA, everyting works properly, unless the functions I mentioned.
                            So an upgrade process caused the problem not the dust, Any ideeas?
                            • mon2
                              • Dec 2019
                              • 13868
                              Too many different posters in this same thread.
                              After the DFU - does your touchbar function? Can you boot Catalina with an external media for testing?
                              • nelusab
                                • Aug 2022
                                • 27
                                • România
                                #35
                                The touch bar fuction works ok, I couldn' check it until installing the OS, but now works ok. Also the screen backlight is working, the system boots prety well.
                                • nelusab
                                  • Aug 2022
                                  • 27
                                  • România
                                  #36
                                  I've allready booted from Catalina. Catalina was the first OS i've cloned, then i.ve tried an upgrade with the results I've reported, and after that I've cloned SONOMA on internal SSD. So yes I can boot on Catalina from an external SSD, having both SONOMA and CATALINA on external SSD. As I said the behaviour is the same on both OS
                                  • mon2
                                    • Dec 2019
                                    • 13868
                                    Is the camera hardware detected under Sonoma?
                                    Review this thread:
                                    Camera stopped working after updating mac… - Apple Community
                                    • nelusab
                                      • Aug 2022
                                      • 27
                                      • România
                                      #38
                                      No, harware not detected, I also checked the harware with Apple Diagnostc tool and no issues where listed. I'm asking myself if something happened with ROM SPI during the first upgrade from Catalina to Sonoma. The upgrading process includes an iBoot version upgrade, and perhaps some changes in the U4770 ROM bin file.
                                      • mon2
                                        • Dec 2019
                                        • 13868
                                        From post # 23 - what is the history of this machine?
                                        You have only upgraded the software and lost these functions?
                                        If yes, then it is just crap software from Apple. Suggest to contact their technical support wannabe propeller heads to ask how they broke this machine. Checking hardware is a waste of time since the software they have supplied broke a working logic board from one OS to another. The enumeration of the camera will be over I2C / SMBUS. Such a bus requires a bus master which is driven by firmware. Either way, they wrote the software so they should know how to fix it. Do investigate with their technical support and continue to post your updates here with their feedback and ideally the resolution.
                                        Pos # 37 links a work around by rolling back the OS version which you may want to consider.
                                        • nelusab
                                          • Aug 2022
                                          • 27
                                          • România
                                          #40
                                          Solved! It was the display flex cable. The 5V CAM line was damaged.
                                          • Gcnewbie
                                            Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                                            by Gcnewbie
                                            Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                                            I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                                            My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                                            I opened the...
                                            03-29-2024, 06:55 AM
                                          • baglaivlad
                                            MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                                            by baglaivlad
                                            Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                                            Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                                            01-09-2024, 09:55 PM
                                          • hummel
                                            Dell Liatitude E7440 - ambient thermal sensor
                                            by hummel
                                            I need help finding the thermistor/sensor responsible for ambient temp. detection in E7440. The laptop randomly powers off with thermal event "ambient thermal sensor -148*C". I have schematics and board view but unable to determine which component is responsible for sensing the ambient temp. I simlpy don't understand how it work from the schematic below:
                                            Could somebody more experienced help?
                                            Schematics and board view attached.
                                            https://www.badcaps.net/forum/troubl...heory/troubles...
                                            11-23-2023, 12:14 PM
                                          • veedo
                                            Apple Macbook Pro A2338 EMC8162 lid sensor doesn't work
                                            by veedo
                                            I have an Macbook Pro A2338 after small liquid damage, all working fine but keyboard was sticky so I have replaced palmrest for genuine second hand and now lid sensor doesn't recognize when I'm closing the lid. Display is always on, can't find sensor for that model, can someone explain my how does it work, where that flex is if there is any.
                                            Maybe that the motherboard issue, not sure where to start.
                                            Thank You
                                            03-03-2025, 02:34 PM
                                          • obelix24
                                            Macbook Air 2020 (a2179) - touch id not working
                                            by obelix24
                                            Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                            I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                            02-09-2025, 12:57 PM
