Acer N20C1 LA-J871P Missing +VCC_CORE and +VCC_GT
  • Comp_Pro
    • Jun 2020
    • 33
    Hello all,
    I have this Acer motherboard LA-J871P the issue with this board is that it turns on but does not show any video or post. I measured the voltages of all the coils and all voltages are present except for +VCC_CORE and +VCC_GT. Schematic and board view can be found here at the bottom of the post. This has a dedicated graphics chip on it and that is getting voltage as well.
    I checked the driver IC PUZ2, PUZ3, PUZ4, PUZ5 and all have 5V on the ENABLE pin 3. However still no output from +VCC_CORE and +VCC_GT.
    Any ideas what the issue might be? Thank you.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer N20C1 LA-J871P Missing +VCC_CORE and +VCC_GT
    Power Plane is given on page3 of schematic. Check which rail is missing.
    • myth77
      acer la-e921p dramrst missing but vcccore present!?
      by myth77
      This laptop came with problem turning on, no picture. PU1401 was getting hot and shorted on NVVDDS_BST1 line. After replacing all was ok on first...i have every voltage, even vcccore, but no picture...then i noticed that dramrst was only 0.07 Vol. First, i dont understand how it is possible to have vcccore without dramrst!? tried with two different bios but the same, signal DDR_DRAMRST# only rises to 0,07V. plt_rst is ok. I tried three different ram sticks. Any ideas?
      boardview and schmetic attached...
      01-23-2023, 01:08 PM
    • ugamazing
      820-02020 PPBUS_AON missing
      by ugamazing
      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
      02-05-2025, 04:21 PM
    • jpreza
      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
      by jpreza
      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
      Looking at the card, it appears to be missing the following:
      1x 1.0uH inductor - orange square
      2x...
      11-01-2024, 10:54 PM
    • gurj1979
      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
      by gurj1979
      Hey guys.
      Need help with this one.
      Fan not spinning due to missing PWN Fan signal.
      Also 5 seconds from powering up it freezes, unless in BIOS.
      But as soon as Windows starts to load, it will freeze.
      CPU is COLD / Room temp when it freezes.
      I've replaced the CPU, same problem.
      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
      Replaced fan - same problem.
      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
      08-19-2024, 05:22 PM
    • salopian
      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
      by salopian
      Hello. I would need some advice please.
      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
      I have already replaced the logic board with another...
      02-27-2021, 07:30 AM
