820-01958 - Missing PP3V3_S5 - No liquid damage
  • duwane
    • Mar 2022
    • 57
    • New Zealand
    Hi All.
    I have an 820-01958 T2 board from a 2020 A2179 that does not want to boot.
    No visible signs of any liquid damage. Green/orange light is present on charger, and switches over to 20v (unless I plug a battery in, then it doesn't switch and stays at 5v). Not sure this if the battery issue is relevant to not booting though as battery does not appear to charge, so could just be a faulty battery.
    Right after negotiation happens from 5v to 20v, board draws around 180 - 250mA, then settles between 30 and 45mA thereafter where it stays.
    The main issue as I see it is that PP3V3_S5 is missing, so boot sequence can't proceed.
    Machine is able to go into DFU mode, but I have tried both revive, and restore many times with no luck. Both fail with an error 4014 something along the lines of the machine being forced in DFU mode.
    I have not found any rails shorted to ground as of yet. I have refloated (not reballed) U7800, and a brief warming of the T2 chip with flux to see if that helped things along, but made no difference except for a slight current draw increase while the T2 chip was hot.
    Measured Voltages:
    PPBUS_G3H: 12.6v
    PP3v3_G3H: 3.29v
    PP1V8_SLPS2R: 1.8v
    PP3V_G3H: 2.99v
    LDO_CORE: 1.49v
    LDO_RTC: 1.49v
    PMU_VPUMP: 4.97v
    PP1v1_SLPS2SR: 1.1v
    PP1V8_SLPS2R: 1.8v
    PP3V3_G3H_RTC: 3.29v
    PMU_LDO3_OUT: 1.79v
    P1V8G3S_EN: 1.8v
    P1V8_G3S: 1.79v
    P5VG3S_EN: 3.29v
    P5VG3S_PGOOD: 1.78v
    PMU_ACTIVE_READY: 1.791v
    P3V3G3S_EN: 0v
    P3V3_GS: 0v
    PP3v3_S5: 0v
    PP3V3_AWAKE: 3.29v
    All other _AWAKE values match their respective voltages
    PP3V3_S5 resistance to ground: 86.6k ohm.
    PP3V3_S5 diode reading to ground: 0.353v
    All PM_SLP_Sx_L values pulse when turning on, but I am not able to see what voltage they are pulsing to (I don't have a scope)
    As you can see from the above voltages, based on the schematic page 63, all of the inputs relevant to PP3V3_S5 to U7800 are present, and all outputs are there except PP3V3_S5 and PD_HIO_PWR_EN.
    Is it safe to assume that the issue here is the PMIC (U7800)? Are there any other tests I can use to confirm that it isn't CPU, T2, or NAND failure? Any other measuremants that I can take to confirm even further that the issue is U7800?
    All help appreciated.
    Thanks in advance!
  • mon2
    • 14735
    Re: 820-01958 - Missing PP3V3_S5 - No liquid damage
    Error 4014
    https://logi.wiki/index.php/DFU_Mode_Restore_(Macs)
    • duwane
      • Mar 2022
      • 57
      • New Zealand
      Quick update for anyone coming to this in the future. I ended up fixing this device. Corrupt firmware was stopping PP3V3_S5 from being produced by the PMIC.
      I was getting DFU failure error 4014 when trying to revive or restore the machine from a host laptop running Catalina using a USB-A to USB-C cable.
      I tried several cables, but all failed with the same error. I was about to give up, but tried one last thing. I then ran Apple Configurator 2 on a machine running Monterey, and used a usb-c to usb-c cable, and the revive finished successfully!
      So the moral of the story is, don't believe what it says in the Apple article about how to do a DFU being able to use any machine as a host as long as its running macOS 10.15.6 or later. Use a machine running the latest version, and it seems to be more successful than using an older macOS version.
      • zaratustrax
        • Aug 2015
        • 10
        • mexico
        I tried with a Monterrey and Apple configurator says it needs Sonoma
        • mon2
          • 14735
          We purchased a relatively current unit to do the same and run Sonoma.
            Acer Chromebook CB713-1W-329V Chromebook 13 Specification for Upgrade or Repair
            This specification for the Acer Chromebook CB713-1W-329V Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CB713-1W-329V boardview and CB713-1W-329V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
            09-06-2024, 07:25 AM
          • Instafixx
            Macbook A2179 820-01958
            by Instafixx
            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
            I checked the Power Sequences below and found this -
            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
            05-20-2023, 05:19 AM
          • questore
            nvme and wifi error after liquid metal spill
            by questore
            Someone brought me a liquid metal damaged motherboard.
            First I have removed alll liquid metal from the board.
            0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
            Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
            There are 2 things that not working.
            1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
            2. nvme devices are not detected on either of the 2 slots....
            11-11-2025, 01:16 AM
          • silver60618
            How to clean Liquid Metal from under CPU?
            by silver60618
            Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
            The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
            Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
            07-11-2025, 01:47 PM
          • Hondaman
            Liquid cooling?
            by Hondaman
            I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
            (After previous generation hardware [Gigabyte] didn't...
            05-08-2025, 09:37 PM
