identify sata connector
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    What type of sata connector is this? From normal use, pins connecting to the board broke. Looking for replacement.
    I have spare xbox 360 sata connectors, tried to solder it. 5v to 5v, but drive won't spin. Just faint ding ant that's it.
  • mon2
    • Dec 2019
    • 14316
    Re: identify sata connector
    What are you trying to repair? Logic board details?
    Are the pics of the bad or good connector?
    Show the pics of the contacts inside the connector housing.
    • mosfetratus
      Sure Not
      • Feb 2019
      • 174
      • Resistron
      This is USB adapter. I want to replace connector in the picture. But i could hack a xbox 360 cable, but don't know what i do wrong. Because drive won't spin, but i get 5 volts.
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        I did DIY sata connector with salvaged laptops female connector.
        But i get two klicks and thats it. Drive doesn't spin.
        Yellow wire - 12V
        Black - GND
        Red - 5V
        Blue - GND
        • mosfetratus
          Sure Not
          • Feb 2019
          • 174
          • Resistron
          Well, i fixed the problem. I needed to connect data lines, without them drive wont spin,. But still, i cannot find a replacement for such connector, because of unusual soldering layout. Every connector is inline.
            • 21145
            https://www.ebay.co.uk/itm/114555106...=item1aac04345 You can find that type of connector on external 2.5" SATA HDD caddy`s. I have 2 with same connector.You can desolder them from the PCB.
            • DynaxSC
              GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
              by DynaxSC
              I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
              There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
              The board is generally working now, all PCIe ports are working, Windows installs normally.
              However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
              The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
              03-10-2025, 12:27 PM
            • reformatt
              LCD Connector identify or source
              by reformatt
              Trying to identify where to source the LCD connectors on the motherboard side for a HP 14-cf2051la. This one came in with liquid damage to the connector and the flex cable. It appeared to clean up ok, however customer says that display blanks out intermittently. It's a 30 pin EDP flat ribbon cable on motherboard side. Believe it to be a HEDWIG-6050A3155301-MB-A01 motherboard.
              I've stolen the connector from another HP motherboard which matches up but it's not the best since it's been kicking around my donor pile for a while. This connector is different to most flip type ones I have...
              03-25-2024, 08:29 PM
            • gabri2211
              Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
              by gabri2211
              Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
              This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
              This NEXUS connector broke.
              Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
              The Xbox has a power supply that provides 12 volts on all outputs, so the power...
              07-28-2025, 07:13 PM
            • TMTGTR
              An Xbox One PSU Odyssey
              by TMTGTR
              Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
              =>Background:
              I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
              06-17-2022, 05:40 PM
            • Tomylee
              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
              by Tomylee
              Sorry for the person who’s going to read all this !
              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
              07-11-2025, 11:52 AM
