bq717
  • ashiq
    • Dec 2020
    • 20
    • india
    bq717
    bq717 charging ic equvalent any ic ??
    • 21467
    Re: bq717
    use the forum search you`ll find out
    • ashiq
      • Dec 2020
      • 20
      • india
      Re: bq717
      thanks got it...
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • Thomasraud
        Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
        by Thomasraud
        i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
        QUOTED
        -It works on charger (without battery connected-only charger)
        -It works on battery (without charger connected-only battery)
        -& it also works when plugged in battery & charger, but it's not charging the battery
        //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
        and..
        QUOTE
        The IC cannot maintain the input current level
        06-28-2022, 06:47 PM
      • Scoff
        HP Probook 470 G4 - Power and Charging Problem
        by Scoff
        Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
        Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
        07-03-2023, 09:28 AM
      • SluggerB
        Help with trying to fix phone that is not charging (Pics inside)
        by SluggerB
        I have two TCL A30 phones.
        Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
        New Phone: Works fine, bought as a donor board to try and repair Old Phone
        My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
        08-12-2024, 08:11 AM
      • Wang Tingting
        Acer Nitro 5 AN515-57-536Q not charging
        by Wang Tingting
        I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
        report is also good for battery.
        Following https://www.badcaps.net/forum/troubl...arging-circuit,
        • DCIN/VCC: 19.1
        • ACIN/ACDET: 3v
        • REGN/VDD: 6v
        • CMSRC : 19v
        • ACOK: 3.3v
        • ACDRV: it is 19v, not 25V(when charging, the ACDRV
        09-10-2025, 01:46 PM
