Re: [HELP] Lenovo V15-IIL "partial dead"
If you decide to remove any pwm ic, you should also remove mosfets that are controlled by that ic prior to applying power. Unconnected gates of that mosfets will sporadically open, and let input voltage run into output line.
However, your IC has only integrated mosfets, which was removed along with IC as well. So seems its not that case i've mentioned above. Try to replace PU9700.
