[HELP] Lenovo V15-IIL "partial dead"
  • todenkopf
    • Oct 2014
    • 49
    • UA
    Re: [HELP] Lenovo V15-IIL "partial dead"
    Originally posted by phantomEVO
    so game over?
    If you decide to remove any pwm ic, you should also remove mosfets that are controlled by that ic prior to applying power. Unconnected gates of that mosfets will sporadically open, and let input voltage run into output line.
    However, your IC has only integrated mosfets, which was removed along with IC as well. So seems its not that case i've mentioned above. Try to replace PU9700.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      so game over?
      Not over. Though i mentioned it in post#3 that PU9700 is a multi regulator with builtin mosfet+dc -dc circuit but in a hurry overlooked it. Since removing PU9700 means removing all the connected fets also, chances of damage is very unlikely. So you can proceed with further diagnosis.
      • Sephir0th
        • Oct 2020
        • 1289
        Low Ohms readings on 3.3V ALW load side is almost always a dead PCH though.
        FairRepair on YouTube
        • phantomEVO
          • Mar 2013
          • 509
          i don't know how to go ahead. now 3,3valw is totaly shorted....but nothing getting hot...
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Exact resistance on 3VALW rail?? Is the measurement without the ic soldered??
            • Xmaxsi
              • Dec 2018
              • Argentina
              #26
              i have exactly the same issue, only that when i connect the my power supply to the charging port it reads 0.009 amps, it charges the battery but only turn power lights on without power supply, only battery power, but nothing getting hot. it's the weirdest problem i encounter so far in a laptop
              • mon2
                • 14679
                Check the voltage to ground of each pin on mosfet PQ101. Post each measurement.
                Connect the power adapter.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  Since laptop is charging, i dont see any issues in PQ101. You mean to say when power button is pressed,power on indicator glows but no voltage on coils? If so what is the exact consumption after pressing power Button?
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #29
                    Probably not related to issue on hand but I just want to make a note that this board has a common fault
                    Bad solder under CPU, which causes removable RAM not to work. Works with soldered RAM only.
