Help finding part F7140 fuse by the ppbus_3GH coil
  • Dale65
    • May 2018
    • 14
    Hi , Can anyone tell me what the part # is and where to purchase the L7140 fuse by the ppbus_3GH coil for MacBook Air 820-00165-a ?
    Last edited by SMDFlea; 06-23-2022, 05:20 AM. Reason: F7140 fuse by the ppbus_3GH coil
  • mon2
    • 14659
    Re: Help finding part .
    I think you mean F7140. 'F' = fuse. 'L' = inductor.
    F7140 = 8 AMP SMD case style 1206, 24V (or higher) fuse.
    From where do you like to shop for electronic parts ?
    Aliexpress or Mouser / Digikey / Arrow ?
    https://www.digikey.ca/en/products/d...hoCWYkQAvD_BwE
    https://canada.newark.com/bel-fuse/0...oss_price=true
    https://www.mouser.com/ProductDetail...Hu8UmoqA%3D%3D
    https://www.mouser.com/ProductDetail...FfFdnMPQ%3D%3D
    • Dale65
      • May 2018
      • 14
      I will check them out . Thank you !!
      • waterchill
        What part is this coil from a MacBook A2681 ?
        by waterchill
        Hi everyone
        I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
        So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
        IAny ideas? It is from a MacBook A2681
        Thank you...
        08-08-2024, 01:46 AM
      • edugimeno
        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
        by edugimeno
        Hi There!
        I'm trying to help my friend who owns a restaurant be just bought.
        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
        It's stuck using, I guess, the 2 sided tape that comes with the strip
        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
        09-05-2024, 09:34 AM
      • G-Sting
        iPad Pro A1876 SHORT Part Identify Help Needed
        by G-Sting
        So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
        So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
        i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
        SO My main concern is what part should i order what should i search the name for ?
        on Ipad...
        05-15-2025, 09:30 AM
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
