macbook a2337
  • String2016
    • Nov 2015
    • 2238
    • philippines
    macbook a2337
    I need help on this macbook A2337 2020MODEL. The problem is apple icloud activation, is there a way to bypass this?please help
  • mon2
    • 14659
    Re: macbook a2337
    A2237 = T2 model. Not that I am aware of but wait for others to comment. The old hacks are no longer valid from my understanding.
    • ugamazing
      • Jun 2013
      • 171
      • usa
      Re: macbook a2337
      Nope. Not unless you have iCloud account info (email) and can request the account holder remove the FMM association.
      Bypasses a waste of time unless you have a specific need/purpose for the bypass, as it's not an unlock. And as Mon2 mentioned, the previously-working bypasses are no longer viable.
      Apple still winning this one.
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • mkdj
        MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
        by mkdj
        About me, my goal and the equipment I (don't) have:
        I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
        About my issue and my goal:
        A friend of mine has a MacBook Air M1 A2337 that does not...
        04-03-2025, 08:28 AM
      • Adogabriel100
        where to get trusted CD3217. Problem with A2337 Macbook Air
        by Adogabriel100
        Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
        The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
        09-06-2024, 12:06 PM
      • Skrndelj
        Apple Macbook Air M1 A2337 Trackpad problem
        by Skrndelj
        Hello all,
        I am repairing a Macbook A2337 and i have a problem
        The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
        When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
        I inspected the whole board and everything seems fine.
        Can anyone help me as i didn't fiddle with trackpad...
        06-11-2024, 04:26 AM
      • Patrick501
        Macbook Air A2337 dead at 5V/0,00A
        by Patrick501
        Hey,
        I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
        USB Tester: 5V / 0,00A
        PPBUS_AON: 12,3 V
        PP5v_S2: 0 V no short
        PP3v3_S2_UPC: 0 V no short
        PP1v25_S2: 0 V no short
        PPDCIN_AON_CHGR_R: 5 V
        no enable signals for the S2 rails by the U8100
        both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
        PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
        PP1v5_UPC0_LDO_CORE:...
        11-29-2024, 02:47 PM
