A1278 820-3115 stuck in sleep mode
  • guruji
    • Oct 2012
    • 120
    • India
    Hello all
    I have a a1278 820-3115 first no power I changed the smc no I have the fan spin all voltage present even get cpu core 1.1v but no chime no display. I programmed. The bios same problem I notice 2 things the system led is solid and the the spi rom pin 5 and 6 have no voltages in on state. But if I power down the laptop then I see all voltages on the spi rom. Also plt_rst_l i3.3v and buffer side 1.05v.I have changed 3 smc and now the intel hm77 chip also still same problem
    What signals to check.lid switch also okay without ram should give us beeps
  • mon2
    • Dec 2019
    • 14317
    Re: A1278 820-3115 stuck in sleep mode
    What is the exact voltage of PPBUS_G3H ? You can measure @ F7040.
    • guruji
      • Oct 2012
      • 120
      • India
      12.5v ppbus
      • mon2
        • Dec 2019
        • 14317
        What is the voltage of SMC_PM_G2_EN ?
        Voltage of PP5V_S3_AUDIO ? (known bad area for cap faults)
        • guruji
          • Oct 2012
          • 120
          • India
          So
          I get all voltage rails 5v 3.3v 1v 1.5v 1.8v and cpu core is 1.12v
          Cpu_agx missing no voltage.all_sys pwrgd also 3.3v I get clocks also 25mhz
          So this is strange the fan is full speed and on the oscilloscope is see no spi bios communication what is strange when the board is on spi bios chip 5 & 6 have no voltage at all but if I shutdown them pin 5&6 have 3.3v .even plt_rst buffer is 3.3v which goes to a buffer 74lvc1g07 and outputs 1.05v
          So what am I missing now here
          • mon2
            • Dec 2019
            • 14317
            Can you post the requested voltages ?
            • Sergio Kub
              • Jul 2018
              • 169
              • Brasil
              Good afternoon,
              I'm repairing a board similar to this one and with the same symptom:
              Turns on, but stays in sleep with the light on.
              I took these voltage measurements and PPBUS_G3H​ 12.61V - SMC_PM_G2_EN 3.3V - PP5V_S3_AUDIO 5V - all_sys pwrgd = 3.3V
              • Sergio Kub
                • Jul 2018
                • 169
                • Brasil
                Can you help me ?
                • mon2
                  • Dec 2019
                  • 14317
                  Measure the voltage to ground of each pin on the battery connector. Interested in the SMBUS SCL and SDA voltage measurements. The same SMBUS interface is used to configure the PPBUS_G3H voltage by the SMC. My bad - I think you are ok on PPBUS_G3H and the voltage is ~12v6 after boosting.
                  Try a new reflashed bios. Can post some if needed.
                  Click image for larger version  Name:	smbus_D6950.png Views:	0 Size:	73.5 KB ID:	3281796
                  • Sergio Kub
                    • Jul 2018
                    • 169
                    • Brasil
                    J6950
                    1, 2, 3 GND 0V
                    4 - 3.456V
                    5 - 0V
                    6 - 3.456V
                    7, 8, 9 - 12.08V
                    * Measurements with the battery plugged in
                    • Sergio Kub
                      • Jul 2018
                      • 169
                      • Brasil
                      This Mac was showing this defect, I turned the J6955 off and on again and it started working again.
                      Now it stopped again and went into hibernation.​
                      • Sergio Kub
                        • Jul 2018
                        • 169
                        • Brasil
                        I cleaned it with isopropyl alcohol and re-soldered the board in the area of ​​the Bil Connector (J6955) and it was fine. Thank you very much !
                        • mon2
                          • Dec 2019
                          • 14317
                          Well done!!
                          • Sergio Kub
                            • Jul 2018
                            • 169
                            • Brasil
                            It came back with the same defect. How bad
                            • Sergio Kub
                              • Jul 2018
                              • 169
                              • Brasil
                              @mon2
                              Can you help me with this defect. I took several measurements and compared them and everything seems to be ok. Sleep light is on, stuck.
                              • mon2
                                • Dec 2019
                                • 14317
                                Check the voltage to ground of the attached. This signal is from the lid sensor that is working with the trackpad.
                                • Sergio Kub
                                  • Jul 2018
                                  • 169
                                  • Brasil
                                  Voltage to ground 3.125V on both sides of R6961 and C6951 3.47V
                                  • mon2
                                    • Dec 2019
                                    • 14317
                                    Close the lid and check the same points.
                                    • Sergio Kub
                                      • Jul 2018
                                      • 169
                                      • Brasil
                                      Closed the lid Pin5-C6955=0V Pin3-C6951=3.125V
                                      • Sergio Kub
                                        • Jul 2018
                                        • 169
                                        • Brasil
                                        I noticed that when I close the lid, without the bil connector connected, the standby light goes off.
                                        • survivalbloke
                                          Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
                                          by survivalbloke
                                          This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
                                          03-20-2025, 02:29 PM
                                        • cappernicus
                                          Satellite r945-p440 - Hard crash coming out of sleep
                                          by cappernicus
                                          Toshiba Satellite r945-p440
                                          Motherboard: FAM2SY2 A3256A
                                          I do not have a schematic or board file
                                          I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
                                          04-16-2025, 05:31 PM
                                        • stormanimal83
                                          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                          by stormanimal83
                                          Hey....
                                          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                          01-18-2024, 02:15 PM
                                        • denem271
                                          A1278 820-2936 Rev.B Sleep light on
                                          by denem271
                                          Hi everyone
                                          I have this model of Macbook that has sleep light on, also i can hear fan and hdd working, battery charging is ok, ac adapter has green and orange light, already tried smc reset with keyboard method with no result, i would like to know where to start with motherboard.
                                          Thanks in advance.
                                          02-06-2022, 10:15 PM
                                        • ekozeko333
                                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                          by ekozeko333
                                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                          🔥 The Problem Started After Suspected ESD/PD Fault
                                          I experienced a power issue or ESD event through a USB-C charger
                                          After that, the NX20P5090 power switch was visibly burned and was replaced
                                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
