Powers on everything, keyboard types LCD works, all functions there, however it gets to OS progress bar and then hits error support code -9000F (which is easily fixed with DFU reset) . Thought it was the keyboard so orderered a new on, tested that board on a good board and it went into DFU, so put the keyboard back into this board and no luck. Tested power button, it turns it off and on no issue, what could be causing this board to not go into DFU whatsoever? Battery is good as well. This is new to me and was wondering if anyone has a solution, the board is not activation lock, it just needs to get DFU restored to get rid of the -9000F support error to get into OS install.
					MacBook Air 13" A1932 Wont DFU, Turns on etc.
 Re: MacBook Air 13" A1932 Wont DFU, Turns on etc.
 Hey mon2 how are you? So this does not explain the DFU issue. This error -9000F can be easily fixed with a DFU restore. There is no data on this computer and needs to get restored to fix this error. Our wifi is good as well. Sadly it wont get into DFU.sigpic
 MEOWING IN THE IMPOSSIBLE UNIVERSE!Comment
 I guess this is a no clue for anyone? Also got it plugged into an external ethernet and it booted to the error again. So I have no idea what is to come of it.sigpic
 How did you confirm this? I.e. what was the fix?
 Was going to suggest the T2 ROM, but sounds like you got it resolved!Comment
 the battery controller is blocked, the laptop has been sitting for a long time, maybe. you need to connect a working battery, if the laptop does not see the battery, it will slow down. try booting the laptop by holding the shift keyComment
 Assuming...7 Photos
			by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
			Apple MacBook Air Retina A1932 820-01521 Schematic & Board View...-
							Channel: Schematics and Boardviews
			by RezendesHello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
 I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
 The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...-
							Channel: Schematic Requests ONLY!
			by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
- Loading...
