MacBook Air 13" A1932 Wont DFU, Turns on etc.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Powers on everything, keyboard types LCD works, all functions there, however it gets to OS progress bar and then hits error support code -9000F (which is easily fixed with DFU reset) . Thought it was the keyboard so orderered a new on, tested that board on a good board and it went into DFU, so put the keyboard back into this board and no luck. Tested power button, it turns it off and on no issue, what could be causing this board to not go into DFU whatsoever? Battery is good as well. This is new to me and was wondering if anyone has a solution, the board is not activation lock, it just needs to get DFU restored to get rid of the -9000F support error to get into OS install.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • Dec 2019
    • 14669
    Re: MacBook Air 13" A1932 Wont DFU, Turns on etc.
    https://discussions.apple.com/thread/250501103
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Hey mon2 how are you? So this does not explain the DFU issue. This error -9000F can be easily fixed with a DFU restore. There is no data on this computer and needs to get restored to fix this error. Our wifi is good as well. Sadly it wont get into DFU.
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Any idea?
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          I guess this is a no clue for anyone? Also got it plugged into an external ethernet and it booted to the error again. So I have no idea what is to come of it.
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            I believe we found the issue. Controller chip was not allowing communication between the USB cables besides charging. Will keep you posted.
            sigpic
            • mon2
              • Dec 2019
              • 14669
              Interesting. So booting from USB media should also fail. Does it?
              What are the diode readings for the usb connector pins of each ACE controller?
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                Yes usb media shows then fails.
                sigpic
                • mon2
                  • Dec 2019
                  • 14669
                  Good stuff. Check on the esd diodes on the usb connector with the diode mode.
                  • ugamazing
                    • Jun 2013
                    • 171
                    • usa
                    How did you confirm this? I.e. what was the fix?
                    Was going to suggest the T2 ROM, but sounds like you got it resolved!
                    • mich6el
                      • Dec 2015
                      • 18
                      • Ukraine
                      the battery controller is blocked, the laptop has been sitting for a long time, maybe. you need to connect a working battery, if the laptop does not see the battery, it will slow down. try booting the laptop by holding the shift key
