Lenovo G40 strange problem .
  • mo000
    • Nov 2017
    • 276
    • algeria
    hi .
    i have lenovo G40-80 ACLU3/ACLU4 NM-A361 power on with the battery only if the adapter present and keeps on even i remove the adapter but without adapter and with the battery only the laptop turns on for 2 sec and goes off
    the laptop charging the battery and working on battery fine but if i turn it off no power on again on battery unless i insert the adapter .
    i have 16v on pin 1 and 2 of battery connector
    3v on pin2 and 0.3 on pin3 and 3VALW present only when i press on powerbtn .
    i change the battery with working one but same problem
    i try to update the bios from the windows but when the laptop restart to complete bios update shows message **the update bios failed no connected battery ** but the battery is connected and fully charged .
  • mon2
    • Dec 2019
    • 14202
    Re: Lenovo G40 strange problem .
    Can you clarify ?
    Do you mean 3v on pin 3 and 0.3 on pin 4 of the BATTERY CONNECTOR ?
    Is PD305 present on your board ?
    • mo000
      • Nov 2017
      • 276
      • algeria
      Originally posted by mon2
      Can you clarify ?
      yes of the battery connector
      PD305 not present on the board .
      • mo000
        • Nov 2017
        • 276
        • algeria
        any help ?
        • mon2
          • Dec 2019
          • 14202
          Review the main power rail with only the charged battery. What is the voltage?
          This voltage travels from the battery to the main rail through the 'battery mosfet'. It may be defective but check the voltages on the mosfet pins.
          Interested in the following:
          Pin 1-2-3 = source pins.
          Pin 4 = gate pin.
          Pin 5-6-7-8 = drain pins.
          Check the voltage to ground of this mosfet.
          • mo000
            • Nov 2017
            • 276
            • algeria
            Pin 4 = gate pin.
            I check the mosfet PQ303
            sourc and drain = 16v
            gate =0v
            • mo000
              • Nov 2017
              • 276
              • algeria
              any help?
              • mon2
                • Dec 2019
                • 14202
                I think that I may not have the proper schematic.
                1) If you have it - please post it or link it if it is on this forum.
                2) Locate the charger IC on the logic board and share the details. It should be close to the DCIN adapter connector. Post the full markings on the IC.
                The ACTUAL schematic may not be available but let us continue with the G40-70 schematic which appears to be similar.
                a) PQ303 appears to be allowing for the battery voltage to reach the logic board.
                b) without the AC adapter, using only the battery, allow for the logic board to turn ON. After it turns off, measure again the voltages on PQ303.
                Post the readings.
                • mon2
                  • Dec 2019
                  • 14202
                  Confirm again the voltages of the SMBUS signals - check the voltages BEFORE and AFTER each of the series resistors.
                  If the logic board is not able to detect the battery, then most likely the SMBUS communications is failing. SMBUS (I2C) is used to communicate with the BMS (battery management system) logic board that is inside the battery pack. This BMS board holds the model / serial # / # of charge cycles / configuration of the battery pack.
                  If you allow for the logic board WITH the battery & AC adapter to boot into Windows -> does Windows show detection of the battery ?
                  • mo000
                    • Nov 2017
                    • 276
                    • algeria
                    Post the readings.
                    i use only the battery the voltage on PQ303 source and drain = 16v gate=0v
                    • mo000
                      • Nov 2017
                      • 276
                      • algeria
                      the voltage ON SMBUS=3.3V
                      yes windows detect the battery and the percent of charging .
                      • NConstantinou
                        LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                        by NConstantinou
                        Dear all,
                        i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                        the laptop DOES NOT POWER ON..
                        with it old battery it does power on.
                        i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                        when i shutdown the laptop does not power on.
                        does anyone have any solution!
                        when is not power on the usb c voltage tester shows 5v 1.3A
                        when i disconnect battery and power on and then connect battery the tester...
                        12-10-2024, 04:52 AM
                      • GabrielS24
                        Lenovo E540 battery problem
                        by GabrielS24
                        Hello! I'm here to look for solutions to reset the EEPROM memory of a Lenovo E540 battery of 62Wh and 540mAh. I even bought a new one on the market (aftermarket BTIBM30) because I couldn't find an original one but it doesn't work. The laptop sees the percentage but blocks the battery charging probably because of the Chinese BMS. In the bios I don't have an option for the battery and I didn't find an older version (v1.57). I replaced the Lenovo BMS with Chinese cells but in windows it doesn't read the battery percentage and says it needs to be changed. I have 12v between D and the red wire....
                        04-16-2025, 05:23 AM
                      • code share
                        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                        by code share
                        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                        Here's what I've tried so far:
                        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                        • Booted successfully on AC power only with the battery disconnected
                        • Visual inspection of the battery — no swelling, burn marks, or connector damage
                        • Battery
                        04-21-2025, 12:50 PM
                      • NConstantinou
                        LENOVO GYG41/GYG51 NM-D131 REV:1.0 BATTERY PROBLEM
                        by NConstantinou
                        Dear all
                        i have the above laptop which had problem with charging and was repaired. the laptop battery need to be replace also and i did but laptop did not power on with new battery.
                        installing old battery back, power comes on.
                        i noticed on battery connector instead of 3.3v on pins 3 and 4, i get 2.9-3.3v and is flactuating.
                        can someone help!!!
                        11-26-2024, 06:08 AM
                      • akwky
                        by akwky
                        Hi!
                        04-14-2025, 01:56 PM
