LENOVO GYG41/GYG51 NM-D131 REV:1.0 BATTERY PROBLEM
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    Dear all
    i have the above laptop which had problem with charging and was repaired. the laptop battery need to be replace also and i did but laptop did not power on with new battery.
    installing old battery back, power comes on.
    i noticed on battery connector instead of 3.3v on pins 3 and 4, i get 2.9-3.3v and is flactuating.
    can someone help!!!
  • mon2
    • 14240
    New battery is probably defective. Test another. The voltage will vary with logic level swings of high and low states.
    • NConstantinou
      • May 2017
      • 335
      • Cyprus
      i have tried a second brand new battery and i got the same result.
      i plugged the battery while the laptop was running with AC adaptor with lenovo utility recognized the battery BUT upon restart didn't power on.
      • mon2
        • 14240
        Remove all power. Remove the battery. Measure each mosfet with resistance mode to check if there are any leaks.
        • NConstantinou
          • May 2017
          • 335
          • Cyprus
          By removing all power and measuring resistance locks ok..
          what is noticed by applying power is the 3.3v on ic pu2001 is giving the problem. there i have the 5v output but 3.3v is flactuating. the ic is not shown as short. i must order it.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • ferah831208
            by ferah831208
            03-18-2025, 01:18 AM
