Hp 17 dar62cmb6a0 board charging no power
  • NConstantinou
    • May 2017
    • 335
    • Cyprus
    Dear all,
    i have this mobo which has the following.
    19v rail is ok.
    3.3 and 5v are missing.
    the 3.3 and 5v ic's are not short. pins 8,9,15,16 (marked as SW)do not have any output on either chip.
    On page 35 of schematic ic NB670 (3v) PC223 on NB670BST side i get 4.85v BUT on the other side of capacitor i get nothing. capacitor is not shorted. i di-solder PL22 and still the same results.
    the same reading i got for NB669 (5v) PC234.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp 17 dar62cmb6a0 board charging no power
    You will get output only when all the inputs and enable's are there and there is no short on output side.
    So measure pin 1/6/12/13/11 of PU3 and post it here. Resistance on PL22 coil and pin6 of PU3??
    DC jack glows solid white or is it blinking??
    • NConstantinou
      • May 2017
      • 335
      • Cyprus
      Thanks for the reply mcplslg123,
      on the mobo i do not see any IC pu3.
      the ic's for 3.3 and 5v are PU9 and pU10. did you mean those!
      the resistance of PL22 is 0.8OHMS.
      The changer light is solid white.
      • mon2
        • Dec 2019
        • 14239
        On PU9 & PU10 -> check the voltage of the EN (enable) pin # 13 on each. This is an active HIGH enable pin.
        If the EN = '1' (logic high) then the regulator is being requested to turn ON.
        • NConstantinou
          • May 2017
          • 335
          • Cyprus
          ON pu9,pu10 ON PIN 13 S5_ON I HAVE 0V. I MEASURED ALSO ON SIO. BUT ON
          BIOS I DO GET 3.3V,KEYBOARD CONNECTOR AND POWER BUTTON.
          I MEASURED PU9 AND I HAVE
          PIN 1 19V
          PIN 6 3.3V
          PIN 10 4.83V
          PIN 11 5V
          PIN 12 5V
          13 0V
          MEASURING THE RESISTANCE ON CN12 POWER CONNECTOR BETWEEN BLACK AND RED I GET 2.5M OHMS. IS THAT CORRECT!
          • mon2
            • Dec 2019
            • 14239
            1) check the resistance to ground of S5_ON signal line. Remove all power, meter in resistance scale to measure. If you see '1', change to the next higher scale on your meter.
            With '0' on the S5_ON = EN, the regulators are instructed to remain OFF.
            2)
            2.5 megaohms is ok and means there is no short.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Sorry, I actually meant PU9
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Resistance on PL22 Coil at 0.8 Ohms is too low and indicates short. REmove the coil PL22 and measure resistance on both pads to determine which side is shorted. You may need to inject voltage to find out bad components(if short is on output side and this is the most likely scenario.
                • NConstantinou
                  • May 2017
                  • 335
                  • Cyprus
                  The resistance to ground for s5_on is .326m ohms
                  the resistance to ground for pl22 is 56k
                  AT THIS MOMENT AS I WAS LOOKING AT THE MOBO I NOTICED PQ45 PINS 5,6,7,8 ARE SHORT.
                  THESE PINS ARE CONNECTED TO R350, PC442 AND PIN 7 ON PU17.
                  I REMOVED PQ45 AND STILL HAVE SHORT ON PINS 5-8.
                  I WILL REMOVE IC PU17 TO SEE IF SHORT IS GONE.
                  THANKS.
                  DO YOU BELEIVE THAT MAY CAUSE 3.3 AND 5V IC NOT TO STARTUP!
                  BY REMOVING PU17 I NOTICED THAT PIN 9 THERMAL PAD IS CONNECTED TO GROUND. IT SHOULDN'T.
                  I STILL GETTING SHORT ON PIN 7
                  • NConstantinou
                    • May 2017
                    • 335
                    • Cyprus
                    I have removed on side of pl37 that goes to 3 capacitors and then to vcc_gfx and short is there.
                    The 3 capacitors are electrolitic pc440,pc441 and pc438.
                    What can i do!!!!
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Post#3 mentions resistance on PL22 is 0.8 Ohms whereas post#9 mentions 56K for the same coil. Which one is correct??
                      It seems to me you are going in wrong direction. PQ45/PL37 stands for GFX_Core and its a low voltage,high current rail. So resistance will be very low. Are you sure its showing shorted? Better you post exact resistance on PL37 Coil in Ohms mode(meter set to 200 Ohms).
                      • NConstantinou
                        • May 2017
                        • 335
                        • Cyprus
                        You are right. USING ANALOG meter resistance of PL37 is 3 OHMS and PL22 is 50k using other digital meter
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          You should focus on 5V rail first. On this mb, if +5V PCU is not available, there will be no output on +3V coil(PU9 uses +5VPCU as VCC).What about ADP_ID?? Known good bios flashed??
                          Do you have a dc supply??
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            PU10,Pin11 resistance in Ohms??
                            Pin12,PU10-Feedback status??
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              3 Ohms on GFXcore is suspect if cpu is taken out from socket.If the reading is with cpu inside the socket, it may be somewhat ok.
                              Your board is socket type or cpu is soldered??
                              • NConstantinou
                                • May 2017
                                • 335
                                • Cyprus
                                Thanks for the help
                                On PU10 Pin6 has 5v so i do have +5vPCU
                                on Pin 11 i also have 5V resistance 1.6MOHMS
                                on Pin 12 i have 5.5v resistance 23MOHMS
                                AD_ID i have .47v
                                On pc228 i also have 5v
                                processor is solder on mobo.
                                yes i do have power supply. when i connected power supply amps were 200ma
                                • NConstantinou
                                  • May 2017
                                  • 335
                                  • Cyprus
                                  i did not flash the Bios because i know that if charging light is on then BIOS is ok. is that correct!
                                  what should be the reading for AD_ID!
                                  • NConstantinou
                                    • May 2017
                                    • 335
                                    • Cyprus
                                    Ad_id voltage on hp laptop
                                    Could someone let me know what must be the voltage of ad_id!!
                                    • mon2
                                      • Dec 2019
                                      • 14239
                                      Re: Ad_id voltage on hp laptop
                                      It will vary with the adapter and logic board.
                                      Which exact laptop model are you working with?
                                      • NConstantinou
                                        • May 2017
                                        • 335
                                        • Cyprus
                                        It is HP 17 dar62cmb60a
                                        Windsor, Ontario
                                        I am having a problem with power on
                                        Charging light is stable but no 3.3 and 5v
                                        I have 5v on pin 6,alw but not on coils
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
