Blackview BV9500 Plus Backlight issue
  • filippia1981
    • Mar 2021
    • 29
    • Greece
    Hi, I have replaced the screen of a BV9500 Plus but I don't have backlight.
    Can anyone help me what might be the issue? kind regards
  • Cornito
    Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
    by Cornito
    Hello Team,
    I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
    Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
    Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
    08-08-2024, 08:09 AM
  • cheebster
    iPad Pro 12.9 5th Gen Backlight Issue
    by cheebster
    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
    Anyone...
    05-20-2025, 09:17 AM
  • Cornito
    TCL 65C715 backlight issue
    by Cornito
    Hello team,
    I'm back with another topic.
    It's a 65C715 TCL tv with backlight issue.
    But the problem is a bit strange.
    When I took this tv from the marketplace backlight didn't work but picture was ok.
    Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
    Putting all back together the tv worked fine for weeks. => Contact issue??
    Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
    06-09-2024, 02:24 AM
  • shellybelly
    Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
    by shellybelly
    Back Story
    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
    08-27-2023, 10:40 PM
  • Riananyaina
    MacBook A1708 820-00840-A backlight issue
    by Riananyaina
    Hello Everyone ,
    today I'm coming to you regarding my issue which is no Backlight .
    I have image on my screen but no light .
    The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
    First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
    Please find below few informations which can help for the analysis...
    04-24-2023, 05:03 AM
