Acer A515-52 LA-G521P EH5AW
  • DrFalken
    • May 2008
    • 122
    Hi guys !
    this laptop came yesterday because turns on but won't POST, only a black screen and CPU becomes a little hot.
    After usual checks (RAM, PSU, CMOS reset, caps discharge...) I've removed the M/B and find these:
    • PQZ1 exploded: half onboard, half stuck on keyboard...
    • a hole in PUZ2
    (see attached pics)
    Both have been removed.
    +VCC_CORE looks a short to GND (what resistance to GND should measure ?)
    PQZ2, PQZ3 & PQZ4 have been removed and checked against shorts (S-G, S-D, G-D).
    The following have been checked working:
    - PC9100
    - PC9101
    - PC9102
    What else can I check before replacing PQZ1 & PUZ2 ?
    Thank you
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Acer A515-52 LA-G521P EH5AW
    99% chance CPU will be dead, better not waste time.
    • DrFalken
      • May 2008
      • 122
      Nothing more to check ?
      Right after removing bottom case (so dead PQZ1 & PUZ2 were still soldered), I've measured about 0.7V @VCC_CORE...is there a chance CPU can still be working ?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Was that a dual mosfet or high side mosfet?? If yes, SOC is gone as @piernov has already advised.
        • DrFalken
          • May 2008
          • 122
          PUZ2 is a dual mosfet driver
          PQZ1 is a high side mosfet
          Can I inject a very low voltage (ie starting from 0.5-0.6V) on VCC_CORE to check if SOC is really shorted or (maybe) some caps on the other side (see pics) ?
          Thank you !
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            You can but perhaps waste of time. Have seen such damage on many many boards. So move on.
            • DrFalken
              • May 2008
              • 122
              Tried injecting the following voltages on VCC_CORE:
              • 0.6V @ 1A -> 0.4V (VCC_VCORE multimeter reading)
              • 0.75V @ 1.5A -> 0.5V
              • 0.9V @ 2A -> 0.67V
              At 0.9V@2A SOC started to heat up a little bit (barely detectable with the finger)
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                What are you upto??When you apply voltage at vcore, its natural for cpu to heat up.
                • DrFalken
                  • May 2008
                  • 122
                  I'm trying to check if CPU/SOC is dead or the short is caused by caps on the other side.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Its dead already, so keep on experimenting to satisfy your qwery.
                    • DrFalken
                      • May 2008
                      • 122
                      PQZ1 & PUZ2 replaced
                      VCC_Core = 0.79V
                      Timeline:
                      - 0: push power button, no display, power led turn blue, fan spin
                      - 5s: fan turn off
                      - 22s: power led turn off
                      - 26s: power led turn blue, fan spin
                      - 32s: fan turn off
                      - 60s: the SOC become hot, fan turn on and doesn't turn off anymore
                      SOC RIP ?
                      • vannix
                        • Mar 2018
                        • 74
                        • Italy
                        i have a customer with the same motherboard (i7-8th + mx150) and the same situation in a notebook that does not boot after he take a flight with the computer packed in the luggage.
                        All.voltages are ok. No short, nothing heat except cpu.
                        Moving the ram module in the other slot it power on and off every 3 secs for 10 Times.
                        Reading your thread i'm also suspecting in bad cpu/soc
                        • mon2
                          • Dec 2019
                          • 13870
                          Remove all peripherals / SSD / hard drive / RAM module(s).
                          Do you hear any memory missing beeps upon power up ?
                          • vannix
                            • Mar 2018
                            • 74
                            • Italy
                            Nothing
                            Only blue led on
                            • mon2
                              • Dec 2019
                              • 13870
                              From the schematic -> appears that the BLUE led is from the battery ?
                              Can you remove or disconnect the battery and attempt the same power up with the official known good power adapter ?
                              Also, with the adapter (only) check the DCIN mosfets which are often a root cause of all evil.
                              Perhaps baggage X-rays nuked the bios but too early to tell (although they claim they are safe to electronic equipment). The bios will then have to be reflashed.
                              See attached -> measure the voltage at the referenced checkpoints. Post the readings.
                              • vannix
                                • Mar 2018
                                • 74
                                • Italy
                                The bios reflash has been the 1st test. Without success..
                                Battery is disconnected. It has 2 leds, power (blue), battery (blue / orange). The battery charger circuit seems ok. Battery charges normally. And with battery or with dc i get the same result.
                                Tomorrow i'll post all voltage measurement
                                • mon2
                                  • Dec 2019
                                  • 13870
                                  Not an expert on this but the KBC KB9022 also features an internal flash memory. Perhaps this internal firmware (8051 based code) has been corrupted. From my limited knowledge on this topic, the main BIOS I believe is able to reflash the KB9022 but wait on advice from others. Just a FYI.
                                  • DanielDacko
                                    • Mar 2015
                                    • 325
                                    • Macedonia
                                    PQZ1 shot 19v straight to the cpu and killed it, you are milking a dead cow, don't waste time anymore.
                                    I don't provide help for people using CH341A and a clip.
                                    • vannix
                                      • Mar 2018
                                      • 74
                                      • Italy
                                      To be sure i can try to reflash it
                                      https://www.badcaps.net/forum/showpo...13&postcount=8
                                      • mon2
                                        • Dec 2019
                                        • 13870
                                        Sounds good but do also check the resistance to ground of the VCC_CORE rail. Remove all power -> meter in resistance mode -> post the reading to confirm the CPU is still ok.
                                        • andrhouseolly
                                          Acer Aspire 5 a515-52g, EH5AW LA-G521P Rev.1a does not start.
                                          by andrhouseolly
                                          Hi goodday to all.
                                          I really ask for help.
                                          There are two motherboards (absolutely identical) Acer Aspire 5 a515-52g, EH5AW LA-G521P.
                                          Both boards have exactly the same fault symptoms. It turns on, the power indicator lights up for 5 seconds, turns off (the fan does not spin).
                                          Both boards are flashed with Bios Main and Bios EC from the “Bios Acer A515 LA-G521P FULL TEST” topic. XM25QH128AHIG replaced by W25Q128JVSIQ (also NOR-FLASH, XM was not detected by the programmer). On one of the boards, KB9022 was changed, followed by firmware. The fault persists on both boards....
                                          03-29-2024, 02:41 PM
                                        • Yehuda170
                                          Lenovo Legion Y740-15ICHg LA-G132P blown PQZ1 mosfet
                                          by Yehuda170
                                          PQZ1 was taken out by someone else.
                                          its probably a dual mosfet. but all traces destroyed ,so hard for me to tell what goes to where
                                          does anyone have a boardview or schematics. or a high quality picture to tell which ic is PQZ1...
                                          11-03-2021, 01:02 AM
                                        • grimacelord
                                          Dell | LA-K034P REV 1.0 | Possible Shorted CPU?
                                          by grimacelord
                                          Hello. I think I may have a problem with the CPU, but I was hoping someone could look at what I have done here and confirm so I don't waste more time on this one.
                                          Original Problem:
                                          No Power.
                                          Troubleshooting:
                                          Thermal camera showed MOSFET PQZ1 getting really hot and inductor PLZ01 was reading short on both sides.
                                          Replaced PQZ1 with new B03N03R MOSFET.
                                          Laptop now charges and powers on, but only for about 10 seconds before it shuts down abruptly. The fan also runs high during the few moments the laptop is...
                                          11-10-2023, 11:58 AM
                                        • RabidNative
                                          Acer AN515-55-57
                                          by RabidNative
                                          Hey All,
                                          Looking at the boardview and schematic provided in the request section for this board. I have been trying to wrap my head around the powerup cycle of this laptop.
                                          Digging through and testing using the provided information has led me to a lack of +VCC_CORE that is preventing startup. It looks like +Vcc_Core is supplied by D2/S1 of PQZ1 which is closed by D1 of PQZ1. Am I missing something?
                                          When testing for the presence of +19VB_CPU i was testing all the boardview callouts for it which lead me to PQA1 pins 2,3,4. Pins 2 and 3 show 19v, however, pin...
                                          08-13-2023, 07:48 PM
                                        • questore
                                          HP 250 G6 LA-E801P Please help identify IC.
                                          by questore
                                          Hello Everyone,
                                          I have a laptop that has a faulty IC, the boardview and schematic cannot help to identify it.
                                          Board has 3 identical IC on it named my boardview: PUG1, PUA1, PUZ2.
                                          Shematics are not helpfull cause they give the ic as RT9610CGQW_WDFN8 and that is not correct. (pin 3 should be DRVON and it is not by datasheet)
                                          its a 8 pin IC and has marking of "CGJ" on it.
                                          Can you help me what it could be?...
                                          04-29-2025, 05:18 AM
