Acer A515-52 LA-G521P EH5AW
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer A515-52 LA-G521P EH5AW
    Originally posted by DanielDacko
    PQZ1 shot 19v straight to the cpu and killed it, you are milking a dead cow, don't waste time anymore.
    That was the case with original OP and not @vannix.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      KB9022 will not get programmed from main bios as ec is not blank. Updating the formware from windows will update ec firmware as well which is not possible here. So you need to flash kbc separately.
      • vannix
        • Mar 2018
        • 74
        • Italy
        Originally posted by mon2
        See attached -> measure the voltage at the referenced checkpoints. Post the readings.
        1=3=4=19,65v
        2=24,02v
        Sounds good but do also check the resistance to ground of the VCC_CORE rail. Remove all power -> meter in resistance mode -> post the reading to confirm the CPU is still ok.
        NAME / USE FOR / OHM TO GND / VOLTAGE
        PL401 / +5ALWP / >500K / 5,236V
        PL402 / +3ALWP / >500K / 3,332V
        PL502 / +1,2VP / >500K / 1,211V
        PLZ1 / +VCC_CORE / 3,2 / 0,6 to 1V
        PLZ2 / +VCC_CORE / 3,2 / 0,6 to 1V
        PLG1 / +VCC_GT / 5,6 / 0,0 to 0,4V
        PL1002 / +1,35VSDGPUP / 602 / 1,361V
        PL1202 / +VGACORE / 8,4 / 0,906V
        PL1203 / +VGACORE / 8,4 / 0,906V
        with the ram inserted in the slot furthest from the cpu this morning i noticed that for a moment it showed the acer logo before becoming like in the attached video
        with the ram near the cpu the +VCC_CORE and +VCC_GT are 0,000v and it shutdown after 3 seconds, then on again, then off....... this for 10 times. then it stay off.
        without ram it stay on with same voltage except for:
        PLG1 / +VCC_GT -> stable to 0,021v
        PLZ1-PLZ2 / +VCC_CORE -> stable to 0,858v
        since this morning the pc started up for a moment i didn't reprogram the EC yet, because i think the problem is with the cpu or some bad soldering near it
        can @DrFalken confirm the PLG1 / +VCC_GT voltage with the board powered on?
        • DrFalken
          • May 2008
          • 122
          Originally posted by vannix
          1=3=4=19,65v
          2=24,02v
          Board powered.
          PLG1 to GND:
          - 5 Ohm
          - 0 V
          • vannix
            • Mar 2018
            • 74
            • Italy
            Thank you for your measurement, however is difficult to understand how much vccgt must be for this board, even reading on the web there is not enough information. I'll do other tests these days, if in the meantime there are other suggestions they are welcome
            • DanielDacko
              • Mar 2015
              • 325
              • Macedonia
              #26
              Sorry, didn't saw that. Well, that happens when people hijack someone's else thread, instead of opening new one.
              I don't provide help for people using CH341A and a clip.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                Yes, It happens sometimes with all of us.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  You cant measure VCCGT with simple DMM on newer boards. There may be a slight deflection on your DMM while turning on but wont show any readings. You need a scope to check that. If you are sure about the resistance on VCC_GT, then remove the coil and inject 0.7V-0.8V on the consuming side(The side which goes to cpu) and see if there is display.
                  • vannix
                    • Mar 2018
                    • 74
                    • Italy
                    #29
                    [Small OT]
                    I don't think this is a thread hijack as the problem is very similar if not the same. Do you think it is better to open a new thread for the same pc, the same board and probably the same problem?
                    I think it is useful for users who will search on this forum or on google to have a unique reference for similar problems and that have a boot behavior the same as mine and DrFalken's.
                    This obviously doesn't mean that the thread has to become 50 pages long and be written for years for totally different problems.
                    I personally hate wasting so much time reading various threads that have similar symptoms and always the same ending.
                    Anyway i say thank you for the observation you made, because this was my personal opinion and it can be wrong.
                    [End OT]
                    You are right, using even a small chinese oscilloscope i can read a fast voltage ranging from 0 to about 1.2v and then it drops to about 0.4v after a few seconds. The schematic shows "0-1.52v / 31A" so i can assume that it's correct.
                    I have made these measurements when the pc is started and it shows the artifacts on the screen (it rarely happens that it starts up). I noticed that after about 1 minute the cpu is not very hot (about 65 degrees with heatsink without fan) but PLZ1 and PLZ2 are about 95 degrees. Cpu core probably draws too much current?
                    EDIT: the consumption from the power supply is very high, using a bench power supply it absorbs about 2 amps with only the lcd display connected and a ram module.
                    With cpu at about 60C i have 0,8ohm between +VCC_CORE and GND.
                    When cpu reaches 70C the board draw about 3,3 amps and the 2 coils are more than 100C. +VCC_CORE to GND is 0,3ohm. The cpu is dead....
                    It's a shame because it's an 8th gen i7, but with newer acer notebooks i'm not lucky.
                    Thanks to all for the help, i will offer the customer a new or a refurbished board.
                    • andrhouseolly
                      Acer Aspire 5 a515-52g, EH5AW LA-G521P Rev.1a does not start.
                      by andrhouseolly
                      Hi goodday to all.
                      I really ask for help.
                      There are two motherboards (absolutely identical) Acer Aspire 5 a515-52g, EH5AW LA-G521P.
                      Both boards have exactly the same fault symptoms. It turns on, the power indicator lights up for 5 seconds, turns off (the fan does not spin).
                      Both boards are flashed with Bios Main and Bios EC from the “Bios Acer A515 LA-G521P FULL TEST” topic. XM25QH128AHIG replaced by W25Q128JVSIQ (also NOR-FLASH, XM was not detected by the programmer). On one of the boards, KB9022 was changed, followed by firmware. The fault persists on both boards....
                      03-29-2024, 02:41 PM
                    • Yehuda170
                      Lenovo Legion Y740-15ICHg LA-G132P blown PQZ1 mosfet
                      by Yehuda170
                      PQZ1 was taken out by someone else.
                      its probably a dual mosfet. but all traces destroyed ,so hard for me to tell what goes to where
                      does anyone have a boardview or schematics. or a high quality picture to tell which ic is PQZ1...
                      11-03-2021, 01:02 AM
                    • grimacelord
                      Dell | LA-K034P REV 1.0 | Possible Shorted CPU?
                      by grimacelord
                      Hello. I think I may have a problem with the CPU, but I was hoping someone could look at what I have done here and confirm so I don't waste more time on this one.
                      Original Problem:
                      No Power.
                      Troubleshooting:
                      Thermal camera showed MOSFET PQZ1 getting really hot and inductor PLZ01 was reading short on both sides.
                      Replaced PQZ1 with new B03N03R MOSFET.
                      Laptop now charges and powers on, but only for about 10 seconds before it shuts down abruptly. The fan also runs high during the few moments the laptop is...
                      11-10-2023, 11:58 AM
                    • RabidNative
                      Acer AN515-55-57
                      by RabidNative
                      Hey All,
                      Looking at the boardview and schematic provided in the request section for this board. I have been trying to wrap my head around the powerup cycle of this laptop.
                      Digging through and testing using the provided information has led me to a lack of +VCC_CORE that is preventing startup. It looks like +Vcc_Core is supplied by D2/S1 of PQZ1 which is closed by D1 of PQZ1. Am I missing something?
                      When testing for the presence of +19VB_CPU i was testing all the boardview callouts for it which lead me to PQA1 pins 2,3,4. Pins 2 and 3 show 19v, however, pin...
                      08-13-2023, 07:48 PM
                    • questore
                      HP 250 G6 LA-E801P Please help identify IC.
                      by questore
                      Hello Everyone,
                      I have a laptop that has a faulty IC, the boardview and schematic cannot help to identify it.
                      Board has 3 identical IC on it named my boardview: PUG1, PUA1, PUZ2.
                      Shematics are not helpfull cause they give the ic as RT9610CGQW_WDFN8 and that is not correct. (pin 3 should be DRVON and it is not by datasheet)
                      its a 8 pin IC and has marking of "CGJ" on it.
                      Can you help me what it could be?...
                      04-29-2025, 05:18 AM
