I have this asus GL503E showing blue screen error.When i check the board the core area supply section getting really hot. it is a 3 phase core supply .on one of the phase the lower gate of the fet (PQ99) gate having no pwm it is low condition.all other 2 phase lower and upper gate have the pwm. I have changed the "PU6"and the fets still same any solution.
asus GL503E blue screen error
Re: asus GL503E blue screen error
Install who crasched and provide error information after scanning when bluescreen occurs. Install this in safe mode and then run windows normally for the error to occur. Then again in the crash mode you can gather information about the bug in the who crashed program.
https://www.resplendence.com/whocrashedLast edited by mayss; 05-26-2022, 12:18 PM. -
by chinhASUS Q420V
Serial number: RAN0LP034069431
Mb: UX3404_MB
:NB6371A_MB_V3
Attached is the main bios
Channel: BIOS Requests ONLY!
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by LvsitanoI am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
First... -
by FallenOne008Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself... -
by krigehi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
- Loading...
