asus GL503E blue screen error
  • ashiq
    • Dec 2020
    • 20
    • india
    I have this asus GL503E showing blue screen error.When i check the board the core area supply section getting really hot. it is a 3 phase core supply .on one of the phase the lower gate of the fet (PQ99) gate having no pwm it is low condition.all other 2 phase lower and upper gate have the pwm. I have changed the "PU6"and the fets still same any solution.
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: asus GL503E blue screen error
    Install who crasched and provide error information after scanning when bluescreen occurs. Install this in safe mode and then run windows normally for the error to occur. Then again in the crash mode you can gather information about the bug in the who crashed program.
    https://www.resplendence.com/whocrashed
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      why u ask for help and just dont replace that ISL?
      • ashiq
        • Dec 2020
        • 20
        • india
        its not getting in safemode after the startup logo its gets in the bluescreen error "stop code whea unexpected error code"
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Most likely its SOC problem.
          • mayss
            • Nov 2016
            • 30
            • Polska
            Make a copy of the bios batch memory and post on the forum for Me-Region wipe.
            • jonny0404
              asus e14BAFA_MB REV 2.2 ONBOARD RAM BLUE SCREEN HELP
              by jonny0404
              hello god friends can some one would be kind to tell me which memory ram i need to disable i cant find the schematic or boarview of these laptop do i need to disolder only one memory ram? here are teh pics.thanks...
              08-06-2025, 02:14 AM
            • chinh
              ASUS ZENBOOK Q420V Start the computer with a blue screen
              by chinh
              ASUS Q420V
              Serial number: RAN0LP034069431
              Mb: UX3404_MB
              :NB6371A_MB_V3
              Attached is the main bios
              06-15-2024, 08:36 PM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Lvsitano
              Asus X532FL 3.2V at source and gate
              by Lvsitano
              I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
              First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
              I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
              First...
              06-26-2024, 02:13 PM
            • FallenOne008
              Asus G712L No Screen Backlight
              by FallenOne008
              Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
              The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
              03-31-2025, 08:27 PM
