Capacitor values in boardview
  • mrkmpn
    • Apr 2022
    • 62
    I am trying to determine the value of a blown capacitor, and the boadview shows the values for many of the capacitors and other components on this board, but all of the information blank on others.
    Is there any relevance to the fact that some of these values are left out, or is it just inconsistency by whoever created the boardviews?
    Is there any way to deteremine if one without infrormation matches one that shows those details?
    • 21403
    Re: Capacitor values in boardview
    Whats the boardview filename, PCB you`re working on from what make/model,and the name of the boardview software and version
    • mrkmpn
      • Apr 2022
      • 62
      Boardview filename:
      "Asus FX63V DABKLMB28A0 FX503VD Rev 2.2 60NR0GN0-MB3020 BoardView.fz"
      MOBO Board number"
      DABKLMB28A0 Rev: A
      Asus part number:
      60NB0GQ0-MB1140
      Make Model of laptop:
      Asus GL503VD-EB72
      Boardview software:
      Openboardview v8.0
      It shows, for example the values and package size for C99, but not for AC99 (which is the one I need)
      **EDIT**
      I realize the boardview isn't identical to the mobo I am working on, but it's very similar, and the only one I;ve been able to find so far,.
      • reformatt
        • Feb 2020
        • 1439
        Have you noticed that only one side of this board has no values listed? It's possible that the boardview doesn't have these values, or it could be the way openboardview interprets the FZ file format. I note that the new version of Openboardview 9.0.2 refuses to open this file.
        Anyway, rule of thumb here is that it's a decoupling cap across a rail, so fit accordingly. Seems to be a 0604 size, so anything from 2.2uf to 10uf would suffice. Voltage rating should exceed that of the rail it is decoupling of course - if you have 12V on that rail, then cap should be at least 16 to 25V. These smaller caps aren't polarised usually, but + side of any polarised cap to the Vcc side.
        • mrkmpn
          • Apr 2022
          • 62
          No, there may be a pattern to what's 'valued' and what isn't, but it almost seems arbitrary. There are caps nearby that have values, but from what I can tell it seems nothing on 'PVCC_HV' has values. And a couple of caps I checked on the other side have values as well.
          I also tried opening it up in Boardviewer 1.2, since I already had that downloaded, and it shows the same results.
          Thanks for the pointers on replacements. Is it possible the fact that a specific value isn't required might be the reason they aren't labeled?
          • piernov
            • Jan 2016
            • 4437
            • France
            Usually in FZ boardview files if some components have part number information and others don't, the ones without part number information are no stuff.
            In this case the TAS5766 speaker amplifier circuit is no stuff in this boardview. Looking at pictures of this motherboard, some variants of this board have this circuit populated, others don't and instead speaker connector is connected directly to audio codec.
            Anyway if this circuit is populated on your board, AC99 would be a general purpose decoupling capacitor, since voltage comes from the main power rail it must be rated at least 25V, and it looks like it is in an 0603 package, so possibly 10uF.
            Make sure the FZ key is probably entered in the configuration.
            • mrkmpn
              • Apr 2022
              • 62
              Thank you! That makes prefect sense, as this boardview is for a diffrent model than the one I'm working on. And it is an 0603, so this was a great help.
              I wish it was an 0805... I actually have a strip of those already.
              • rashidjafar
                Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                by rashidjafar
                I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                Values for :-
                PC43 : Capacitor [3x1.5mm]
                PL7 : Inductor [2x1mm]
                PC39 : Capacitor [1x0.5mm]
                Any ideas would be appreciated.
                I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                08-07-2025, 05:10 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • luiztessadri
                A1707 820-00928-04 missing component, boardview mismatch
                by luiztessadri
                I have a board that has a component missing but the 820-00928 boardview doesn't have this component. I know it's not a capacitor because both sides are not GND. The board has no sound only boot chime. I already changed MacOS version with full clean install with USB flash. Replaced U6200 and U6300 but still the same. I cleared EFI firmware with Intel FIT but problem persists. All power rails and signal are good. Resistance values of all resistor involved in the circuit are correct. Diode mode shows no discrepancy comparing to OpenBoardView Data. At output or input devices nothing shows. At System...
                10-20-2024, 08:56 PM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • flusher
                A2485 MBP16 M1 820-02100 not charging
                by flusher
                Bought myself a project. Waterdamage to the left wing. Front side got damage on top up to SSD area. Back - near CD3218 both CD3217. Had to replace a lot of caps and resistors to make it perfect. No shorts. Didnt lift any chips yet but microscope shows good balls from sides. Anyway. It powers up and boots fine.
                Right single usbc shows 20v on meter 0 amp
                Left upper usbc shows 5v 0 amp
                Left bottom usbc shows 20v 0 amp
                magsafe shows orange but also does not charge
                nothing produces beep from mac when on
                when off - single usbc and magsafe produce beep but no beep...
                08-27-2025, 08:25 PM
