Capacitor values in boardview
  • mrkmpn
    • Apr 2022
    • 58
    I am trying to determine the value of a blown capacitor, and the boadview shows the values for many of the capacitors and other components on this board, but all of the information blank on others.
    Is there any relevance to the fact that some of these values are left out, or is it just inconsistency by whoever created the boardviews?
    Is there any way to deteremine if one without infrormation matches one that shows those details?
    • 20304
    Re: Capacitor values in boardview
    Whats the boardview filename, PCB you`re working on from what make/model,and the name of the boardview software and version
    • mrkmpn
      • Apr 2022
      • 58
      Boardview filename:
      "Asus FX63V DABKLMB28A0 FX503VD Rev 2.2 60NR0GN0-MB3020 BoardView.fz"
      MOBO Board number"
      DABKLMB28A0 Rev: A
      Asus part number:
      60NB0GQ0-MB1140
      Make Model of laptop:
      Asus GL503VD-EB72
      Boardview software:
      Openboardview v8.0
      It shows, for example the values and package size for C99, but not for AC99 (which is the one I need)
      **EDIT**
      I realize the boardview isn't identical to the mobo I am working on, but it's very similar, and the only one I;ve been able to find so far,.
      • reformatt
        • Feb 2020
        • 1398
        Have you noticed that only one side of this board has no values listed? It's possible that the boardview doesn't have these values, or it could be the way openboardview interprets the FZ file format. I note that the new version of Openboardview 9.0.2 refuses to open this file.
        Anyway, rule of thumb here is that it's a decoupling cap across a rail, so fit accordingly. Seems to be a 0604 size, so anything from 2.2uf to 10uf would suffice. Voltage rating should exceed that of the rail it is decoupling of course - if you have 12V on that rail, then cap should be at least 16 to 25V. These smaller caps aren't polarised usually, but + side of any polarised cap to the Vcc side.
        • mrkmpn
          • Apr 2022
          • 58
          No, there may be a pattern to what's 'valued' and what isn't, but it almost seems arbitrary. There are caps nearby that have values, but from what I can tell it seems nothing on 'PVCC_HV' has values. And a couple of caps I checked on the other side have values as well.
          I also tried opening it up in Boardviewer 1.2, since I already had that downloaded, and it shows the same results.
          Thanks for the pointers on replacements. Is it possible the fact that a specific value isn't required might be the reason they aren't labeled?
          • piernov
            • Jan 2016
            • 4435
            • France
            Usually in FZ boardview files if some components have part number information and others don't, the ones without part number information are no stuff.
            In this case the TAS5766 speaker amplifier circuit is no stuff in this boardview. Looking at pictures of this motherboard, some variants of this board have this circuit populated, others don't and instead speaker connector is connected directly to audio codec.
            Anyway if this circuit is populated on your board, AC99 would be a general purpose decoupling capacitor, since voltage comes from the main power rail it must be rated at least 25V, and it looks like it is in an 0603 package, so possibly 10uF.
            Make sure the FZ key is probably entered in the configuration.
            • mrkmpn
              • Apr 2022
              • 58
              Thank you! That makes prefect sense, as this boardview is for a diffrent model than the one I'm working on. And it is an 0603, so this was a great help.
              I wish it was an 0805... I actually have a strip of those already.
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • luiztessadri
                A1707 820-00928-04 missing component, boardview mismatch
                by luiztessadri
                I have a board that has a component missing but the 820-00928 boardview doesn't have this component. I know it's not a capacitor because both sides are not GND. The board has no sound only boot chime. I already changed MacOS version with full clean install with USB flash. Replaced U6200 and U6300 but still the same. I cleared EFI firmware with Intel FIT but problem persists. All power rails and signal are good. Resistance values of all resistor involved in the circuit are correct. Diode mode shows no discrepancy comparing to OpenBoardView Data. At output or input devices nothing shows. At System...
                10-20-2024, 08:56 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
