Acer E5-576 power on problem
  • JustX
    • Feb 2019
    • 70
    • iran
    Hello
    i have a weird problem and im stuck
    problem is that laptop works fine for sometimes but if i turn it off for a day and comeback tomorrow it wont power on untill i disconnect all voltages and rtc battery and connect them again then turns on.
    i checked the board and everything looked fine so i reprorammed bios and the problem was still the same i even changed kbc and charging ic too.
    any idea?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer E5-576 power on problem
    Check RTC circuit completely.
    • JustX
      • Feb 2019
      • 70
      • iran
      thank you for your response.
      i checked it i didnt find any problem.
      ichecked the charging circuit
      internal battery rating is 14.8v and when i connect the battery it has around 16.5v and when i connect the charger i have around 17v on battery pin
      last night i charged the battery fully and left it for the night today i came back it wouldnt turn on with battery only. when i connect the charger device turned on.
      • mon2
        • 14668
        Remove the battery.
        Does the unit turn on every time with only the original power adapter ?
        • JustX
          • Feb 2019
          • 70
          • iran
          Originally posted by mon2
          Remove the battery.
          no i test that too, at some point it wouldnt turn on at all with or without battery
          i reprogrammed the bios then it turned on after awhile same thing happend but with changing bios ic and program didnt power on anymore.
          i think the pch maybe be the problem
          • Destroyer-Br
            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
            by Destroyer-Br
            I'm working on an Acer Nitro 5 unit with the following specs:
            • Motherboard: LA-J871P Rev: 1B
            • Model: Acer AN515-55-59MT
            • S/N: NHQ7JAL00403906A973400
            • SNID: 03902728734
            Initial Issue
            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
            04-17-2025, 08:18 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Duranitron
            Asus x512dk rev 2.1 power on problem
            by Duranitron
            When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
            Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
            11-26-2024, 10:22 PM
          • Bonaventure Vigil
            ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
            by Bonaventure Vigil
            Dear All,
            Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
            At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
            12-12-2024, 10:22 AM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
