Asus X550JX rev 2.0 not power on !
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello friends
    Got this motherboard with ram buit in that didn't power on : Asus X550JX rev 2.0
    No short to GND At all coils.
    When i connect charger cable ( from power supply ) the lap is on , consumption is going from 0.03 to 1.8 ( with fluctuation = 0.6/1.2/1.6/1.8 ) for second than back to 0.03.
    All voltages are presents when she's on for this second.
    Try anothers bios same issue. changing bios chip same issue too.
    RSMRST IS OK...Plt_rst is present..
    The only thing that i notice is : Pwr_sw at pin 110 U3001 = = 0.133 v ! it must be 3v
    Also Pwr_sw is = 0.133v at D3201 pin 3
    All others voltages at D3201 are present.
    Tracing Pwr_sw from pin 110 to a resistance = R3037 100Kohm...find 3Va from one side but from the side of io is 0.133v...changing resistance still same issue .
    What i miss...what to check else !...thank you
  • mon2
    • Dec 2019
    • 14667
    Re: Asus X550JX rev 2.0 not power on !
    1) Unable to locate D3201 in my Rev 2.0 schematic of the same.
    2) R3037 is also mated with C3010 capacitor to form a RC power on circuit. Check on the condition of C3010 or even consider to desolder this part for testing. After this cap is removed, what is the voltage on PWR_SW# ?
    It should be pulled to ~3v due to R3037 function.
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Thank you mon2
      sorry i mean D6201 (D3201 is at another donar board)
      C3037 is not populated at this motherboard
      It should be pulled to ~3v due to R3037 function = yes i know that's why i change it but still same issue
      Even if i join the 2 pads of R3037 with twizer and get 3 v at pin 110 io and pin 3 of D6201..not power on
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Seems like bad SIO. Not sure though.
        • mon2
          • Dec 2019
          • 14667
          Ok. See attached.
          There is no D6201 inside my schematic for Rev 2.0 for the logic board.
          There is a D6201 inside the Rev 2.1 schematic.
          Remove all power. Meter in resistance mode (lowest scale).
          Check the resistance to ground with one meter probe on
          PWR_SW#
          and the other meter probe to ground.
          What is the resistance reading in ohms ? Also post the meter scale used for the measurement.
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            Ok
            my board is Rev 2.0 but i use 2.1 BRD.
            I use automatic range , so just put my meter scale at the ohm signal ( am i right ! )
            pin 1 = lid_sw = 156 kohm
            pin 2 = GND
            pin 3 = pwr-sw = 3.530kohm
            pin 4 = pwr_led = 08.40mohm
            pin 5 = +3Va_ec = 289.6kohm
            • mon2
              • Dec 2019
              • 14667
              Using flux & hot air, remove the ESD device @ D6201. Make a note of the orientation of this device for replacement after this test.
              Then measure again the resistance to ground for pin # 3. Post the reading.
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                same = 3.530kohm
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  When i change R3037 ( 100Kohm ) , whent measure at the donar board i find 96 kohm..so it's ok but when soldered at this board and measured = 60kohm.
                  Seems like bad SIO as mcplslg mention before !!
                  • koby058
                    • Jan 2017
                    • 387
                    • israel
                    what is SIO ?
                    • mon2
                      • Dec 2019
                      • 14667
                      Attached.
                      • koby058
                        • Jan 2017
                        • 387
                        • israel
                        So this one can be replaced, yes? or it is programed?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          This is not the way to conclude. A resistor will not show its actual value when soldered on board. I'll suggest to apply flux and warm the sio pins slightly to see if it makes any difference. ON some asus, power switch is powered by RTC circuit. So do check whether there is any issues within RTC circuit. last option is to replace the SIO.
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • bajdik
                            Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                            by bajdik
                            I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                            Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                            I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                            Unfortunately, I don’t have access to the schematic.
                            It seems to me that when I bend the board, something changes.
                            Could this...
                            08-13-2025, 07:26 AM
                          • garretofriviaaaaa
                            Asus TUF Dash FX516PM Power Issue
                            by garretofriviaaaaa
                            Hello, I've had a problem with this laptop for a while. I've replaced the motherboard after it died, and it was seemingly working fine after, but it stopped powering on after I shut it down. if I remove the battery connector and plug it back in, it will boot fine, but if I shut it down again it will not power up after that until I unplug and replug the battery in. When I press the power button the caps lock light will light for half a second but will not boot. I've tried replacing the RAM and the battery but still the same issue. The only thing I've found to get it to turn on consistently was...
                            08-29-2025, 05:47 PM
                          • MakNCheese
                            ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                            by MakNCheese
                            I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                            Symptoms:
                            • Severe lag across the system, including BIOS navigation.
                            • Slow boot times and unresponsive performance in Windows.
                            • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                            • No error messages or BSODs, just extreme sluggishness.
                            What I've Tried:
                            • Replaced
                            06-04-2025, 12:48 AM
                          • mkdj
                            ASUS X571 no power : battery issue?
                            by mkdj
                            Mark and model: ASUS X571
                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                            Tests already made:
                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                            - I have removed...
                            07-14-2025, 09:16 AM
