da0u93mb6d0 rev:D don't power on, Dc jack light glow
  • Jokerx84
    • Sep 2017
    • 52
    • Hungary
    Hi!
    I would like help with a da0u93mb6d0 rev: D motherboard that doesn't turn on but is charging!
    KBC was a replacement, the dc connector was not lit before
    There was also a Bios exchange, it didn't help
  • Udemzy
    • May 2017
    • 157
    • Guatemala
    Re: da0u93mb6d0 rev don't power on, Dc jack light glow
    First thing First, check all coil impedance and vin section too, then check your charging section, standby ic and SIO requirements.
    Post your dc reading, this will also go a long way to help.
    • Jokerx84
      • Sep 2017
      • 52
      • Hungary
      vin 19,74v
      the charge is OK
      sio what should i check?
      what is standby ic?
      I'm sorry, I'm a beginner
      meanwhile I replaced pu12 RT8223 with tps51125, nothing changed
      • Jokerx84
        • Sep 2017
        • 52
        • Hungary
        if i press the power button, the cpu gets hot for a moment
        • Jokerx84
          • Sep 2017
          • 52
          • Hungary
          update
          when the charger is plugged in the cpu is hot
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Originally posted by Jokerx84
            vin 19,74v
            the charge is OK
            what is standby ic?
            Check the stand by supply PL20/21 ? and the resistance to GND with out power same 2 coils
            Is the Dc jack lights stable or glowing?
            SIO pin 35 120 supply when you press the power ? Don’t short any pins SIO be careful
            • Jokerx84
              • Sep 2017
              • 52
              • Hungary
              PL20= 5.4V 12.5Kohm
              PL21= 3.4V 7.7ohm
              DC Jack lights glow!
              sio pin35=0V Pin120=0V
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Very likely shorted PCH.
                • Jokerx84
                  • Sep 2017
                  • 52
                  • Hungary
                  CPU replaced, now starts, fan is spinning, but the screen is black
