MacBook Pro A1286 Mid 2012 no power, no LED on the charger
  • mon2
    • 14636
    Re: MacBook Pro A1286 Mid 2012 no power, no LED on the charger
    Can you link the video or did the link get censored? Will check it later today.
    • Gigabit2
      • Apr 2022
      • 264
      #162
      https://www.youtube.com/watch?v=rVGMuMGH0Wc
      • Gigabit2
        • Apr 2022
        • 264
        #163
        It is called "Repairing a Mid-2012 13" MacBook Pro with no Video on LCD" on YouTube from dosdude
        • mon2
          • 14636
          Ok - quickly skimmed through the video. For his case, it is the inductor @ L9000 on your board (820-3330) that was fried. He had +3v3 on pin # 1 but a ~1v2 on pin # 2 so the voltage rail on the LCD connector was too low to power the LCD panel.
          We are not so lucky but you can measure again, the voltage pins 2 & 3 of the J9000 LCD connector. What voltage do you read with your meter here ? It should be a solid +3v3.
          • Gigabit2
            • Apr 2022
            • 264
            #165
            Just booted into OS on SSD and using external display, it's a weird situation.
            Slow-ish to boot and has a small black screen whilst loading the OS - but then in the OS works fine and no issues at all.
            Possibly software but is the GPU failing?
            • mon2
              • 14636
              From what I know, if your logic board is NVIDIA which the schematic shows, you should not have this fault. It is the AMD GPU that was the bad boy.
              Remove the keyboard / trackpad cable and test again -> is it faster to boot ?
              • Gigabit2
                • Apr 2022
                • 264
                #167
                All that is connected is SSD and internal display
                • mon2
                  • 14636
                  Not condoning it so best to check with DOSDUDE1 if the NVIDIA GPUs are also flaky ?
                  Found this (mentions AMD only):
                  http://dosdude1.com/gpudisable/
                  PS: I am assuming that you have done the PRAM reset ?
                  Power off, hold the following keys, option,command,P,R (no commas) hold these keys before the start chime, and continue to hold them till you hear the start chime 2 times, then release. allow to boot, the reboot.
                  Watch this video - memory fault:
                  https://www.youtube.com/watch?v=QYLOhbrnhcA
                  • Gigabit2
                    • Apr 2022
                    • 264
                    #169
                    The plot thickens!
                    So I left external monitor and LCD connected for a while after power on, about five minutes.
                    Internal LCD still showing nothing but external display now powered on and cursor is moving from this display to the other even though internal display not showing anything.
                    So seems like is not issue of recognising the display but outputting to it?
                    • Gigabit2
                      • Apr 2022
                      • 264
                      #170
                      Backlight on internal display definitely doesn't seem on, didn't see any flicker on it.
                      No video and shined with phone LED behind and seeing nothing.
                      • Gigabit2
                        • Apr 2022
                        • 264
                        #171
                        Hi mon2,
                        I was able to get pictures of the display connector under the microscope. I show them here for your views.
                        • mon2
                          • 14636
                          While the joints look solid, consider to flux the SMD pads -> low air pressure -> hot air these pads or high recommend to point-to-point touch each pad to reflow each contact.
                          The 2nd picture appears to almost show a potential short but could be my eyes.
                          • Gigabit2
                            • Apr 2022
                            • 264
                            #173
                            Hi mon2,
                            Sadly I think we will have to admit defeat on this board as I think I damaged the connector pads too much whilst removing it.
                            Board is ruined
                            • mon2
                              • 14636
                              Positive outtake - this is your new donor board for future repairs
                              • Gigabit2
                                • Apr 2022
                                • 264
                                #175
                                I assume there is no fix that can be done?
                                • mon2
                                  • 14636
                                  There is a lot of flux in the region so cannot see the pads (if they are even there) from the posted pic.
                                  Use Q-tip and alcohol to clean up this area and to confirm if any of the LVDS pads are still present on the board. Post a fresh pic after the IPA cleaning.
                                  • Gigabit2
                                    • Apr 2022
                                    • 264
                                    #177
                                    Pads are gone
                                    • Gigabit2
                                      • Apr 2022
                                      • 264
                                      #178
                                      This one becomes a donor board.
                                      Thank you for all your help Mr Mon2, until the next time
                                      • SarcasticOP
                                        General question about MacBook power rails for repair.
                                        by SarcasticOP
                                        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                        • PPBUS_G3H (12.6V-12.8V)
                                          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                        • PP3V42_G3H (3.42V)
                                          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                        • PPVRTC_G3H (3.3V)
                                          • This
                                        12-12-2024, 05:50 PM
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • durchfall
                                        MacBook 2011 A1286 power cycle, no chime
                                        by durchfall
                                        I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
                                        What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
                                        01-11-2023, 05:56 AM
