MacBook Pro A1286 Mid 2012 no power, no LED on the charger
  • Gigabit2
    • Apr 2022
    • 264
    #81
    Re: MacBook Pro A1286 Mid 2012 no power, no LED on the charger
    JTAG programmer ordered.
    @mon2 can you help me with finding the file I need to flash?
    • Gigabit2
      • Apr 2022
      • 264
      #82
      Hi mon2,
      Are we sure issue is not somewhere else?
      Looking at DDC circuit, LVDS_DDC_CLK at pin 2 of R9011, is reading 0.72 on 20V scale.
      Suggests monitor not detected?
      • mon2
        • 14636
        Ok. This clk is an output from the logic board -> to the LCD screen.
        Trace this signal back to the mux @ U9270.
        What is the voltage @ R9272, pin # 2 ?
        • Gigabit2
          • Apr 2022
          • 264
          #84
          Will check. Sorry mon2 not trying to say I know anything as you are the expert
          • Gigabit2
            • Apr 2022
            • 264
            #85
            Mon2, pin 2 showing 3.3V.
            But LVDS_DDC_CLK (OUT) showing 0.72V, so is there issue inside this chip U9720 then?
            • mon2
              • 14636
              Can you confirm if you are measuring pin # 2 reading at the chip U9270 ?
              If yes, that is a good reading, yet pin # 3 = LVDS_DDC_CLK is 0v72 ??
              Pin # 2 and pin # 3 should be at the same voltage level.
              Measure to confirm directly at U9270 and then again at another site on the logic board. Perhaps a trace break ?
              While measuring, what is the voltage on pin # 1 of U9270 ?
              • Gigabit2
                • Apr 2022
                • 264
                #87
                Sorry mon2, pin 2 with TP LVDS_DDC_CLK! 0.72V confirmed. 0.72V also on pin 3 so looks ok.
                • Gigabit2
                  • Apr 2022
                  • 264
                  #88
                  U9270 on pin 1 is 0.72V!
                  • Gigabit2
                    • Apr 2022
                    • 264
                    #89
                    Mon2, think then LVDS_EG_DDC_CLK coming from U8000 is low? 0.72V should be higher?
                    This is the cause of the problem?
                    • mon2
                      • 14636
                      Measure & post the voltage readings of the following:
                      PP3V3_S0_LVDSDDCMUX
                      LVDS_DDC_SEL_EG
                      LVDS_DDC_SEL_IG
                      PP3V3_GPU_LVDS_DDC
                      also adding:
                      PP3V3_S0_DDC_LCD
                      Next, remove all power.
                      With the LCD attached - meter in resistance mode - check the resistance between pins 17 & 18 on the LCD connector. This is the resistance check between:
                      LVDS_CONN_A_CLK_F_N
                      and
                      LVDS_CONN_A_CLK_F_P
                      • Gigabit2
                        • Apr 2022
                        • 264
                        #91
                        Hi mon2,
                        I spoke with dosdude2, he is ok to send me dump of 2012 demux chip so I can reflash but he does not think this will resolve the issue
                        I will measure the readings of the above shortly. Thank you once again for your kindness and patience
                        • mon2
                          • 14636
                          Hmm. What are his thoughts on this case?
                          Forgot to ask, is your JTAG tool compatible for reflashing the target Lattice FPGA / CPLD ? Is it based on the FTDI chip set. From our experience, the JTAG tool should have the FTDI MPSSE feature to remain compatible with the Lattice or the many open source toolchains.
                          Is this lcd the compatible lcd for the logic board?
                          I lost an eBay auction yesterday - believe it was the same as yours. Want to have one here for some measurements. Will continue to search for another A1286 2012.
                          A key concern is that your logic board will boot (POST) only if the LCD is removed.
                          Interested in the last batch of readings. You should have boot chime with or without the LCD. So do the measurements with and without the LCD for the resistance check on the lcd connector.
                          • Gigabit2
                            • Apr 2022
                            • 264
                            #93
                            Yes mon2, have boot chime with or without the LCD.
                            • Gigabit2
                              • Apr 2022
                              • 264
                              #94
                              It is HW-USBN-2 I think is compatible?
                              • Gigabit2
                                • Apr 2022
                                • 264
                                #95
                                PP3V3_S0_LVDSDDCMUX at C9270, 3.3 on 20V mode
                                LVDS_DDC_SEL_EG at TP[1] LVDS_DDC_SEL_EG, 3.3 on 20V mode
                                LVDS_DDC_SEL_IG at TP[1] LVDS_DDC_SEL_IG, 00.2 on 200m mode, going to 00.0 to 00.1 back to 00.2
                                PP3V3_GPU_LVDS_DDC at R9270 pin 1, 3.3 on 20V mode
                                PP3V3_S0_DDC_LCD at R9010 pin 1, 3.3 on 20V mode
                                LVDS_CONN_A_CLK_F_N and LVDS_CONN_A_CLK_F_P shows 1 on all modes up to 2m
                                • Gigabit2
                                  • Apr 2022
                                  • 264
                                  #96
                                  Yes, as you will recall it initially did work then went black during usage
                                  • Gigabit2
                                    • Apr 2022
                                    • 264
                                    #97
                                    LVDS_CONN_A_CLK_F_N and LVDS_CONN_A_CLK_F_P shows 00.7 on 200 mode after re-test, with display connected
                                    LVDS_CONN_A_CLK_F_N and LVDS_CONN_A_CLK_F_P shows 00.7 on 200 mode after re-test, without display connected
                                    • mon2
                                      • 14636
                                      These are not good readings. There are 2 select signals for the 4066 mux switch, IG and EG.
                                      Be sure to measure both.
                                      One of these must be 3v3 to enable the lcd signals to flow through this analog switch.
                                      Remove the lcd and check again the voltage of the 4066 enables.
                                      If low, the 4066 switch will remain open. If 3v3, the switch will close and the signal will appear at the lcd connector.
                                      Also, when does the logic board work? After you remove only the lcd LVDS cable ?
                                      • Gigabit2
                                        • Apr 2022
                                        • 264
                                        #99
                                        Hi mon2,
                                        Logic board shows fan spin and chimes with or without display connected.
                                        But no video on internal display when internal display connected, NOR on external.
                                        When I remove internal display, external display works via HDMI.
                                        • Gigabit2
                                          • Apr 2022
                                          • 264
                                          #100
                                          Mon2, if I have cable connected but no LCD at the other end, works fine on external monitor.
                                          But if I connect display, still chimes but no display on internal or external monitor!
                                          • SarcasticOP
                                            General question about MacBook power rails for repair.
                                            by SarcasticOP
                                            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                            • PPBUS_G3H (12.6V-12.8V)
                                              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                            • PP3V42_G3H (3.42V)
                                              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                            • PPVRTC_G3H (3.3V)
                                              • This
                                            12-12-2024, 05:50 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • durchfall
                                            MacBook 2011 A1286 power cycle, no chime
                                            by durchfall
                                            I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
                                            What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
                                            01-11-2023, 05:56 AM
