asus x550jx no power
  • giulio93
    • Aug 2021
    • 258
    • Italy
    Good morning. I have a asus x550jx-xx033h with some problems. First the pc doesn't turn on at all. I checked for a short and I found a shorted mosfet in the main power rail (19V). I remove it and now the pc starts.(All the tests i did were whith just the mobo and nothing else connected to its exept for the power connector.) I feel the chipset becoming worm but nothing on the screen. All the power led are on. The cpu and gpu are death cold. I try to reprogram the bios chip. I tried 3 different bios taken from another topic here in the forum but the result is the same. What do i have to check?
    Thank you very much
  • giulio93
    • Aug 2021
    • 258
    • Italy
    Re: asus x550jx no power
    I mesure the resistances at the cpu coils and they are 0 ohms. I think I have a shorted cpu.. Could be other?
    • giulio93
      • Aug 2021
      • 258
      • Italy
      Guys? No one?
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        Where was the shorted mosfet? Which heats up the smaller die. Just when you plug power heats the smaller die then up? Do. You have al the powlines up . Can you capsldo capslock test with externa keybouard. If you can tab capslock the the board is posting.
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
