MacBook Pro 13 a1278 bad lcd
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    I replaced lcd in this a1278. When turned on it is black, although If i press alt (I should see The list of bootable disks). After that, as soon when os starts, it work. What could it be?
  • mon2
    • 14662
    Re: MacBook Pro 13 a1278 bad lcd
    When it is black, can you see the Apple logo with external flashlight (phone) ?
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      I Think need same lcd with model and rev
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        with same lcd pn it work ok
        • mon2
          • 14662
          see post #2.
          • Adogabriel100
            Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
            by Adogabriel100
            Hey! This is a A1278 macbook 2011.
            Problem: Not turning on / No green light
            Im using by3200s charger.
            Voltajes:
            PPBUS_G3H = 12.26v
            SMC_RESET_L = 3.3v
            PP3V42_G3H = 3.42v
            U7000 =
            Pin 1 CHGR_AGATE = 0v
            Pin 2 CHRG_DCIN = 19v
            Pin 3 CHRG_ACIN = 4.6v
            Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
            Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
            Pin 12 PP3V42_G3H = 3.42v
            Pin 13 CHRG_RST_L = 3.3V
            Pin 14 SMC_BC_ACOK = 0.8V
            Pin 19 PP5V1_CHRG_VDD = 5.05V
            Pin 20 PP5V1_CHRG_VDDP = 5.03V...
            04-01-2024, 01:02 PM
          • Rezendes
            Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
            by Rezendes
            Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
            I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
            The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
            05-10-2024, 02:18 PM
          • pcbmaniac
            MacBook A1278 (3115) No PPBUS_G3H Issue
            by pcbmaniac
            Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
            I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
            1. U7000 Measurements:
              • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
            2. Resistors:
              • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
            Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
            • If I also decide to replace the SMC, do I need to order it pre-programmed,
            12-02-2024, 04:12 PM
          • sizar00740
            macbook pro 13 inch a1278 820-2879
            by sizar00740
            please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
            07-30-2025, 10:21 AM
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
