ASUS ROG GA502D missing 19v
  • jeweemiah
    Learn anything
    • Feb 2022
    • 25
    • Texas
    Hello! No schematics available online for this one sadly.
    Laptop not turning on, no charging light
    I don't understand why my 19v wont show on the output of the first mosfet.
    Should I jump wire only the first mosfet or you guys have any suggestions?
    Any help is appreciated!
    Laptop
  • mon2
    • Dec 2019
    • 14011
    Re: ASUS ROG GA502D missing 19v
    No. Never bypass the part till all details are known.
    What is the history of the unit ? Are you using the proper adapter for this laptop ?
    What are the markings of these 2 mosfets ?
    You will need to trace the mosfets to the closest IC which will likely be the charger IC.
    Post the markings of the charger IC.
    • jeweemiah
      Learn anything
      • Feb 2022
      • 25
      • Texas
      Laptop has been dead for a year, decided to try to fix cause why not.
      Original charger is being used.
      1st mosfet is PKCH2BB, 2nd is M3058M
      Charger IC is bq24780s (Is this right?)
      Voltage in the picture are the only ones that have values.
      How can I possibly find the mosfet for the charging IC?
      I also attached a picture of the front of the board maybe its here? the charging IC is literally at the back slightly below of the these mosfets.
      If you need anything more measured just let me know
      • mon2
        • Dec 2019
        • 14011
        See attached for the datasheets for each.
        The mosfets can be sourced through Aliexpress (most of the time) or you can find a suitable substitute.
        The best starting base is to review the reference schematics from the charger IC vendors which in this case is Texas Instruments (TI). They will note a recommended set of parts and most of the logic board designers will copy the proven reference design.
        PKCH2BB
        https://www.aliexpress.com/wholesale...psort=1&page=1
        M3058M
        bq24780s
        https://www.aliexpress.com/item/1005...rch-mainSearch
        Suggestions:
        When sourcing the mosfets, review each of the mosfet linked to the charger IC and purchase a few of each mosfet. This includes the first 2 mosfet + high side & low side mosfet + battery mosfet - see the reference schematic inside the posted datasheet. Your logic board will offer similar parts.
        While not 100% required at this time, also suggest to source a few of the charging IC from TI from the same vendor. This way you will have all of the replacement parts, if required, with a single shipping charge.
        Just ask the same shop if they can supply each of the above parts.
        If you do not feel comfortable with Aliexpress - can review to find alternatives. Another tech on this forum noted that you have a local electronics market that may stock such parts. There are many options to replace these mosfets as long as they will fit onto the same SMD pads.
        • piernov
          • Jan 2016
          • 4435
          • France
          https://www.badcaps.net/forum/showthread.php?t=90356
          • myth77
            • Feb 2017
            • 380
            • Croatia
            Did you check resistence to gnd on that blue parts? and short on mosfets?
            • jeweemiah
              Learn anything
              • Feb 2022
              • 25
              • Texas
              These are the resistance values measured
              1st mosfet =
              Source: 51.9 kΩ
              Gate: 7.5 MΩ
              Drain: 52 kΩ
              2nd mosfet =
              Source: 51.9 kΩ
              Gate: 7.4 MΩ
              Drain: 0.001 Ω
              Measured 0.001 Ω after the resistor with blue mark.
              Both mosfet Source are connected, and all the components that are connected to the First mosfet drain has all the same resistance.
              also diode mode on the drain side of second mosfet reads 0.00v.
              any thoughts?
              • jeweemiah
                Learn anything
                • Feb 2022
                • 25
                • Texas
                PKCH2BB
                M3058M
                bq24780s
                Suggestions:
                Thank you brother for the input I already ordered them online surprisingly all of them would be under 25 bucks, I will be getting five of them each. I will update if they have arrived!.
                • myth77
                  • Feb 2017
                  • 380
                  • Croatia
                  as you can see you have a short on main power rail, short to gnd. Thats why your mosfet is not opening...to prevent damage to motherboard.
                  The problem is that main power rail is a huge rail...powering everything on the motherboad so it is very difficult to find where is the short.
                  On gaming laptops it is usually the power mosfets on gpu or cpu line...but it could be a capacitor also.
                  Double check the resistence in milohms on main power rail? is it exactly 0,001 ohm?
                  also, make a visual inspection on the whole motherboard to see anything burned maybe or cracked.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    As @myth77 has correctly pointed out, your +19V rail is shorted to GND. You can inject 1V on CLR just after dc-in fets and observe if anything gets hot. Dont inject more then 1V though you can increase amp gradually.
                    • jeweemiah
                      Learn anything
                      • Feb 2022
                      • 25
                      • Texas
                      My bad its actually 0,1 Ω. I can't see any obvious discoloration from passive components to ICs. Tested some sus caps but they are not shorted at all.
                      • jeweemiah
                        Learn anything
                        • Feb 2022
                        • 25
                        • Texas
                        I have also tested resistance to ground on some coils and found out that these two coils are both under 1Ω.. Can I narrow down that the short is somewhere here or near?
                        • myth77
                          • Feb 2017
                          • 380
                          • Croatia
                          If it is exactly 0,1 ohm thats pure short to gnd...lets hope its capacitor...if its mosfet then with that low resistence it probably shorted cpu or gpu also.
                          If you have a power supply do what mcplslg123 advised: inject 1V on CLR just after dc-in fets and observe if anything gets hot with your fingers/hand or use isopropyl alcohol. Dont inject more then 1V though you can increase amp gradually.
                          • jeweemiah
                            Learn anything
                            • Feb 2022
                            • 25
                            • Texas
                            I sadly don't have a power supply . Is there any other options of finding a short? I don't wanna buy a power supply that I will use only one time.
                            I asked a laptop and phone repair shop around town and they said don't accept those kind of requests especially disassembled ones, they suspected that it came from another repair shop. I also specifically said that I will take full accountability to the laptop even if nothing happens lol and they still refused
                            • myth77
                              • Feb 2017
                              • 380
                              • Croatia
                              unfortunately there is no other way. Even if we found boardview for this motherboard it would be like a huge puzzle...you would had to remove/desolder joints and coils and resistors...to narrow things to a possible short area. But because this line is huge...it would take hours and hours of finding and desoldering parts then again soldering... Its near to impossible.
                              • jeweemiah
                                Learn anything
                                • Feb 2022
                                • 25
                                • Texas
                                Imma go and ask a friend of my mine if they have something, meanwhile I will still be updating on some and unusual values and info about the issue or If I can find something online.
                                • jeweemiah
                                  Learn anything
                                  • Feb 2022
                                  • 25
                                  • Texas
                                  Yo guys, am back so firstly I replaced a shorted mosfet and my CLR on the main power rail after the second mosfet is only reading 4.2v
                                  Any thoughts on my next step after?
                                  • mon2
                                    • Dec 2019
                                    • 14011
                                    Remove all power. Meter in resistance mode (lowest scale).
                                    Check the resistance to ground of the 2nd mosfet / main power rail. Post the resistance reading.
                                    Also check if the 2nd mosfet is possibly defective - using resistance checks:
                                    source (1-2-3) & drain (5-6-7-8)
                                    source (1-2-3) & gate (4)
                                    gate (4) & drain (5-6-7-8)
                                    Checking for a low resistance across the above pins. If found, the mosfet is defective and needs to be replaced.
                                    Post the resistance readings.
                                    • jeweemiah
                                      Learn anything
                                      • Feb 2022
                                      • 25
                                      • Texas
                                      All resistances on lowest scale are OL, reading only starts appearing at 200k scale. all values are 100k +.
                                      • mon2
                                        • Dec 2019
                                        • 14011
                                        This mosfet appears to be ok.
                                        Do you see 19v at the first mosfet?
                                        What is the voltage after the mosfet?
                                        Post the voltage readings on the source(1-2-3), gate (4), drain (5-6-7-8) pins of each of the first 2 mosfets.
                                        Then, very very carefully, measure and post the voltage readings of each pin on the charger IC.
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • m0jo1103
                                          Need help.... Lenovo L340-15IRH mosfet missing!
                                          by m0jo1103
                                          Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
                                          05-19-2025, 07:13 AM
                                        • khabib
                                          ASUS STRIX G531GT MISSING PM_SLP_SUS#
                                          by khabib
                                          Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
                                          here what i measure already:
                                          EC_RST# 3.3V
                                          SRTCRST# 3v
                                          +3VA_RTC 3V
                                          RTCRST# 3V
                                          ME_SusPwrDnAck 0V
                                          AC_PRESENT 3.3 V
                                          AC_IN_OC# 0V
                                          PS_ON 3,3V
                                          +3VA_DSW 3.3V
                                          DPWROK_EC /R 3.2V
                                          PM_BATLOW# 3.3V
                                          SM_INTRUDER# 2.8V
                                          PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
                                          THat is can confirm PCH relate issue...
                                          05-28-2024, 01:30 AM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
