MacBook Air A1466 2017 no Power via MagSafe
  • mon2
    • Dec 2019
    • 14662
    Re: MacBook Air A1466 2017 no Power via MagSafe
    No. Not till a voltage higher than this zener is reached, the zener remains out of circuit.
    Remove all power. Meter in resistance mode.
    Check :
    Source and drain
    Source and gate
    Gate and drain
    Of mosfet Q7010. If you have a donor of this part, replace it. Confirm the resistance of the resistors mated to this mosfet.
    • Strolch
      • Nov 2017
      • 245
      • Deutschland
      I do not quite understand. what should i measure it from?
      check :
      Source and drain
      Source and gate
      Gate and drain
      and I take the Q7010 from another board.
      • mon2
        • Dec 2019
        • 14662
        Meter in resistance mode. Check the resistance across source and drain pins of the mosfet.
        The pin function are shown in above posted schematic as S, G, D.
        Then measure the other combinations and post the measurements here. We are checking if the mosfet is defective with a low resistance check.
        • Strolch
          • Nov 2017
          • 245
          • Deutschland
          Hi, :-) thx we made it together. It was the R7012 defective! I exchanged it and now the LED lights up green and orange and I have my 16.4 volts
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • longislandtea
            MacBook Air 2017 A1466 EMC 3178 820-00165-A No power
            by longislandtea
            Hi, I' ve this MacBook Air with a strange problem. This laptop come in to my shop with initial problem PULSING (ON/OFF, no fan)
            I wrote this attached bios dump that I clean me region by ME INJECT software and Macbook Power on but have a strange defect.
            The Macbook Power on only when I connect the AC adapter without battery. It Never power on by clicking power key on keyboard. I also tryed to power on by SMCbypass on the motherboard.
            When Macbook is ON and I press ON/OFF key the macbook go off without problem
            I tryed to clean me region...
            02-14-2021, 10:11 AM
