MacBook Air A1466 2017 no Power via MagSafe
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    Hello, I have a MacBook Air that got some liquid! It worked again, but now it won't load or start with the power adapter! As long as the battery is still charged, the MacBook works normally on battery! But not with a power supply. There is also no green or orange light at the plug! Not even with another Magsafe. Even a new DC power board does not work. It's probably the logic board! Need help. Thanks
  • mon2
    • Dec 2019
    • 14119
    Re: MacBook Air A1466 2017 no Power via MagSafe
    Post the full 820-xxxx # on the logic board to reference the proper schematic.
    Probably 82-00165 ?
    See attached.
    Remove the battery - attach only the known good Apple original power adapter.
    Measure and post the voltage readings on D7005.
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      820-00165-a
      • Strolch
        • Nov 2017
        • 237
        • Deutschland
        great, I just started measuring the D7005! there is nothing on pin 1,2,3! At pin 1 only 0.0010V.
        And with my healthy board there is 16V.
        • mon2
          • Dec 2019
          • 14119
          That was expected.
          See attached. Measure & post the voltages for the referenced points with your magsafe adapter connected.
          • Strolch
            • Nov 2017
            • 237
            • Deutschland
            I have R7010 Pin1= 3,13Volts
            R7011+R7010 Pin2=3,10 Volts
            Q7010= 0Volts
            • mon2
              • Dec 2019
              • 14119
              PPDCIN_G3H is not the proper value @ 3v13.
              Reference:
              https://www.logi.wiki/index.php/Powe...List#820-00165
              It should be PPDCIN_G3H = 18v5.
              Can you test with the other power adapter ?
              • Strolch
                • Nov 2017
                • 237
                • Deutschland
                at J7000 Pin 1 and pin 2 I have 3,14Volts too.
                • Strolch
                  • Nov 2017
                  • 237
                  • Deutschland
                  other Magsafe same!! Volts
                  • Strolch
                    • Nov 2017
                    • 237
                    • Deutschland
                    other board (tats OK!!) I have PPDCIN Q7010= 16,4Volts R7010 pin 1=16,4 Volts, R7011 pin2 =6,7Volts
                    • mon2
                      • Dec 2019
                      • 14119
                      1) confirm the DCIN magsafe board does not have any burnt contacts with your external adapter. Use alcohol to clean the contacts.
                      2) after the above check, take the bridge cable from the working unit off and apply the bridge cable from this non-working unit (DCIN board to the main board) on the known good A1466.
                      Do you see the proper PPDCIN_G3H voltage on the known good A1466 ?
                      Be sure to swap the cables only with power removed from the logic boards!!
                      • Strolch
                        • Nov 2017
                        • 237
                        • Deutschland
                        The good A1466 has 16,4Volts! The Magsafe is 100%ok.
                        • mon2
                          • Dec 2019
                          • 14119
                          Is this using the non-working board's bridge cable ?
                          Now transfer over the daughter board (LIO) onto the non-working board & use the same tested bridge cable.
                          Then test again with the known working Magsafe adapter.
                          Post the voltage readings for PPDCIN_G3H.
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            I did this. I have both logic boards here and tested them with the intact DC board.
                            • mon2
                              • Dec 2019
                              • 14119
                              Any difference in the voltage on D7005 with the swapped LIO board & mating cable ?
                              • reformatt
                                • Feb 2020
                                • 1406
                                Check R7012 voltage with no magsafe attached; should be close to 0V. If not, usually leaky Q7180 after liquid damage.
                                • Strolch
                                  • Nov 2017
                                  • 237
                                  • Deutschland
                                  The DC Board and the bridge cable are 100% ok. and the other 820-00165 A1466 logic board is 100% ok.
                                  i haveR7010 Pin1= 3,13Volts
                                  Q7010= 0Volts
                                  and at J7000 Pin 1 and pin 2 I have 3,14Volts too.
                                  • piernov
                                    • Jan 2016
                                    • 4435
                                    • France
                                    https://logi.wiki/index.php/Magsafe_Sleep_Mode
                                    • Strolch
                                      • Nov 2017
                                      • 237
                                      • Deutschland
                                      So a part on the logic board is defective! I had already exchanged the D7005 after the damage, after that the MacBook worked. But it hasn't been loading for 4 days. No light on Magsafe connector. And as I said, the voltages that I measured.
                                      • Strolch
                                        • Nov 2017
                                        • 237
                                        • Deutschland
                                        D7012 SDZT15R6.8. damage?
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • longislandtea
                                          MacBook Air 2017 A1466 EMC 3178 820-00165-A No power
                                          by longislandtea
                                          Hi, I' ve this MacBook Air with a strange problem. This laptop come in to my shop with initial problem PULSING (ON/OFF, no fan)
                                          I wrote this attached bios dump that I clean me region by ME INJECT software and Macbook Power on but have a strange defect.
                                          The Macbook Power on only when I connect the AC adapter without battery. It Never power on by clicking power key on keyboard. I also tryed to power on by SMCbypass on the motherboard.
                                          When Macbook is ON and I press ON/OFF key the macbook go off without problem
                                          I tryed to clean me region...
                                          02-14-2021, 10:11 AM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
