HP 250 G7 4 long 2 short blinking error
  • rabsonnjala
    mujahid
    • Apr 2021
    • 19
    • malawi
    Hallo,
    I have hp 250 g7 motherboard no: EPK LA-G07DP Rev 1.0. It powers on perfectly but when it tries to load the windows logo while booting, the keyboard starts blinking 4 long and 2 short error codes. i tried to reflash the bios with another file problem continues. Please help
  • mon2
    • Dec 2019
    • 14204
    Re: HP 250 G7 4 long 2 short blinking error
    See attached. Same ?
    • rabsonnjala
      mujahid
      • Apr 2021
      • 19
      • malawi
      mine is giving 4 long 2 short I think its different
      2 - 4 and 4 - 2 might not be the same
      • rabsonnjala
        mujahid
        • Apr 2021
        • 19
        • malawi
        I have also noticed the following error. I have replaced the fan and applied thermal paste and I'm thinking that the thermal ics have problems. can anybody help how to trace the problem? attached is the image and schematic
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • Charrlie
          Sharp Lc-70le734u blinking 2 long 5 short
          by Charrlie
          Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
          So I busted into it and have done the following:
          -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
          07-07-2022, 02:02 PM
        • seifaldenn
          LA-G07EP rev 2.0 i3 7th gen. light blinking 5 long 3 short
          by seifaldenn
          11-09-2022, 01:06 PM
        • cm0002
          Sharp LC-55N7000U 1 long 5 short blinking, no display
          by cm0002
          I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
          Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
          I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
          06-19-2023, 06:21 PM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
