LA-G07EP rev 2.0 i3 7th gen. light blinking 5 long 3 short
  • seifaldenn
    • Apr 2019
    • 45
    • Egebt
  • seifaldenn
    • Apr 2019
    • 45
    • Egebt
    Re: LA-G07EP rev 2.0 i3 7th gen. light blinking 5 long 3 short
    Bin:غزل:
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      Write your device model and upload your original bios file.
      all donations are welcome,
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        Bin:غزل:
        Here's your new file, try it and let me know the result.
        • seifaldenn
          • Apr 2019
          • 45
          • Egebt
          The same problem
          • hardware1
            • Sep 2021
            • 2949
            • N/A
            The file that i had uploaded is a virgin bios from HP website, maybe your issue is related to hardware not a bios issue.
            go to this link and create a new thread.
            https://www.badcaps.net/forum/forumdisplay.php?f=23
            • Ferimonka
              HP Envy 15-FH0501sa 3 long 2 short capls lock light
              by Ferimonka
              Hello guys,
              As per title says I have a Envy 15-FH0501sa , Ryzen 5, 16 Gb version.
              Motherboard number is JPB51 LA-M798P rev.1.0
              SN CND3362R3S
              The laptop is getting power and funs stop spinning after few swcconds. It was liquid damaged so we get it to turn on. However 3 long and 2 shor Caps lock lights showing. Power button turns the laptop on but not off.Battery is charging.
              Please help and advice. I attachet the bios dumb in case the bios is the problem.
              Many thanks.​...
              04-29-2025, 02:17 AM
            • 08caine15
              HP 14s-cf0057TU caps lock blinking 3 long and 2 short
              by 08caine15
              Hi everyone , I need your help with this board and it's giving me a hard time . 3 long and 2 shorts base on HP site it's a MEMORY ERROR , tried replacing RAM it's still the same. RAM VOLTAGE has 1.2V i think it has a complete voltage a 3.3v and there's also ah 2v , tried checking pins if there any damage or unsoldered and everythings good , now I don't what should I do next. Also tried reflashing and programming the bios and still the same, hopefully there's someone who can help me with this since im having like 4 laptop with the same error.
              10-03-2024, 02:23 AM
            • Charrlie
              Sharp Lc-70le734u blinking 2 long 5 short
              by Charrlie
              Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
              So I busted into it and have done the following:
              -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
              07-07-2022, 02:02 PM
            • YasaCh
              Sony kdl 40p5500 red light keeps blinking 3 times
              by YasaCh
              Hello...
              my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
              i opened the back cover no sign of damage on the powery suply or motherboard
              when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
              another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
              07-07-2025, 11:53 AM
            • cm0002
              Sharp LC-55N7000U 1 long 5 short blinking, no display
              by cm0002
              I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
              Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
              I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
              06-19-2023, 06:21 PM
