Dell E5430 doesn't detect charger ID
  • andresi
    • Nov 2020
    • 152
    • INDONESIA
    #41
    Re: Dell E5430 doesn't detect charger ID
    Originally posted by mon2
    Post the voltage readings of PQ3.
    pq3
    pin 1 = 5.1v
    pin 2 = 0.4v
    pin 3 = 0v. (short to ground)
    • mon2
      • Dec 2019
      • 14042
      PQ3 needs to be ON to allow for the adapter ID to be passed to the logic board.
      With the voltage measured on pin #2 of PQ3, it is OFF.
      As a test, carefully, ground pin #1 of PQ3 with a piece of wire to ground.
      Does the adapter get detected?
      With no power, check the 2 resistors that connect to pin #2 of PQ3. Are their values ok? Are they damaged?
      With power, what is the voltage on each of these 2 resistors? The voltage needs to be high enough to turn ON PQ3 when the adapter is plugged in.
      When PQ3 is on, then pin #1 should be LOW = ~0 volts.
      • andresi
        • Nov 2020
        • 152
        • INDONESIA
        #43
        yes i use original charge, and it working with other dell laptops.
        the adapter is detected.
        i test :
        pr14 = 99.7kohm pin#1 3.3v, pin#2 0.422v
        pr16 = 14.25kohm pin#1 0v, pin#2 0.422v
        pr15 = 9.9kohm pin#1 5.128v, pin #2 5.121v
        i check it with battery in. but still plug in not charging
        i turn on warning adapter in bios i got this “Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust the performance to match the power available.
        but i sure the charging and battery workly in other same e5430.
        • mon2
          • Dec 2019
          • 14042
          Watch this video:
          https://youtu.be/OkVFrKVHwfA
          • mon2
            • Dec 2019
            • 14042
            My bad...PQ3 is a PROTECTION transistor.
            If the voltage is very high on the PS_ID line from the external adapter, then PQ3 will turn ON to cause the LOW voltage @ PQ2, pin # 2 = to remove this surge event from reaching the logic board.
            Noting the above, perhaps PQ2 (N-channel) is defective.
            With ~5 volts on the GATE of PQ2, this mosfet (PQ2) is ALWAYS ON.
            See attached. Locate PR11 and apply a solder blob to see if this resolves the issue. If not, then PU1 switch may be defective and needs to be replaced.
            Start with the quick test of bypassing PQ2 with a solder blob @ PR11.
            If this test works - then PQ2 needs to be replaced.
            • andresi
              • Nov 2020
              • 152
              • INDONESIA
              #46
              i already jumper pr11 but still no working, maybe the problem is ic smsc, i will find the same type to replace that ic. thank you sir, i got some many knowledge here.
              • mon2
                • Dec 2019
                • 14042
                Does your logic board complain about the adapter?
                Is the logic board running slower with the proper adapter? This means the power adapter is not being properly detected.
                The original poster of this thread may have had a different issue than your case. The OP could not detect the power adapter. You case is that the battery is not charging.
                Be sure the power adapter is the proper adapter for this logic board and the original from Dell. Otherwise, the PS_ID cannot be read (single wire communication device inside the adapter).
                • toniu-massa
                  Dell 15-5570, CAL50/DAL50 LA-F115p - Does not detect original charger
                  by toniu-massa
                  Hello, everyone!!! Happy New Year to all!!!
                  When I turn on the laptop, the warning appears: You have attached an undersized 0W adapter and blah, blah, blah... The bios says that the adapter is not connected and the battery status is excellent.
                  This laptop has all the voltages at the input, and the charger IC is also normal. There is 3.3V at the PS_ID and I have already tested it with another adapter, also original. The adapter detector also seems to work normally. I am suspecting the SIO. What do you think?
                  On my portable oscilloscope there is a PS_ID signal....
                  01-02-2025, 02:02 PM
                • BTubbs200
                  Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                  by BTubbs200
                  Dell Latitude 5420 P137G
                  Board: LA-K491P REV A01
                  I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                  Board seems to have no shorts, all power rails are fine and show high resistance.
                  When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                  01-24-2025, 08:15 PM
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • exerion5000
                  DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                  by exerion5000
                  Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                  below normal, as if it were operating in an extreme energy...
                  10-15-2023, 02:12 PM
