Dell E5430 doesn't detect charger ID
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Re: Dell E5430 doesn't detect charger ID
    No voltage at pin 4.
    Short pin 3 and 4 while laptop is on with battery connected?
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      3.3V must be present at pin3 now, but is not at pin4 right?
      Become a Badcaps supporter
      Thanks to all supporters.​
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        The is only 5v @ pin #5. no other voltages.
        Plus i see 3.3v @ PR12
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          If the 3.3 is present at pr12, must be present also at pin3 of the PU1, no other way, because the pr12 is directly connected to pin3, so confirm that first?
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            The pin of PR12 that is directed connected to pin #3 is 0v, the other pin of PR12 has 3.3v
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #26
              OK got it, desolder PU1 from the board, and measure the voltages again.
              • mon2
                • 14681
                You must have a broken trace between pin # 3 of PU1 and PR12 - confirm it.
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  #28
                  Without PU1 the 3.3v appear on pin #3 trace, also on both pins of PR12
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #29
                    If that was the case 3.3 should have been present at both side of the resistor. So not the case here. The line was shorted with the old PU1 as I suspected, and the new one is not OK obviously. Or there is a problem with the dock connector, but the measurements with the removed should give the answer.
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #30
                      Short pin3 to pin4 and you are back in the business.
                      • Andreasbest
                        • Aug 2014
                        • 1196
                        • Hellas ( Greece )
                        #31
                        Without PU1?
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #32
                          Originally posted by andreasbest
                          without pu1?
                          Yes.
                          • Andreasbest
                            • Aug 2014
                            • 1196
                            • Hellas ( Greece )
                            #33
                            Wire slipped from my hand and shorted 5v and 3.3v, result shorted U51.
                            Motherboard RIP but at least we tried.
                            Thank you for your time and afford
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #34
                              Cooome ooon man, how you came up with the idea to work with the soldering iron on a powered board!? Can't believe... What a rookie mistake.
                              • Andreasbest
                                • Aug 2014
                                • 1196
                                • Hellas ( Greece )
                                #35
                                I tried to short it with a thin wire while i was in bios to check if the adapter wattage appears, the wire slipped a bit and...
                                No worries, was a old laptop abandoned in my store that i tried to revive it, no loss.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #36
                                  It is clear that this laptop is a cheap old model, but why did you have to kill it this way, and it would be fully operational as long as you did it in a way I advised you to do it. Anyway, let it be your lesson never to draw metal objects near a powered motherboard or if it's absolutely necessary to do that, do it with a tweezers, resting your palm on the table to be precise in the movement of the hand.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    #37
                                    Not expected from someone with 600+ posts in the forum. This was just too kiddish .
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      #38
                                      So true.
                                      Fun fact: it's the same time i did it the last 10 months, previously i shorted a 7510 mb because i removed the USB daughterboard while on battery, still trying to repair it.
                                      I swear i will not do it again.
                                      Meanwhile i succesfully desolder the U51 and traces are perdect, i'll try to replace it from a donor mb.
                                      • andresi
                                        • Nov 2020
                                        • 154
                                        • INDONESIA
                                        #39
                                        i have the problem with my e5430 too. plug in not charging.
                                        data how i got :
                                        Pbatt1
                                        - pin 9,8 = 0.076v without batt and 11v with batt.
                                        - pin 6,7 = 3.3v
                                        - pin 5 = 0v with batt and 3.3v without batt.
                                        PQ2
                                        - pin 1 = 3.3v
                                        - pin 2 = 5.1v
                                        - pin 3 = 3.3v
                                        pu1
                                        - pin 3,4 = 3.3v and pin 3 and 4 get shorted (not to ground)
                                        - pin 5 = 5.1v
                                        pr13 = 33.4 ohm (3.3v in both (pin1 and 2 get buzz))
                                        pr12 = 2.1 k ohm (pin 1 = 3.323v, pin 2 = 3.387v)
                                        I read and measure from the conversation above but it doesn't solved. what do I test next? thanks for helping
                                        • mon2
                                          • 14681
                                          Post the voltage readings of PQ3.
                                          • toniu-massa
                                            Dell 15-5570, CAL50/DAL50 LA-F115p - Does not detect original charger
                                            by toniu-massa
                                            Hello, everyone!!! Happy New Year to all!!!
                                            When I turn on the laptop, the warning appears: You have attached an undersized 0W adapter and blah, blah, blah... The bios says that the adapter is not connected and the battery status is excellent.
                                            This laptop has all the voltages at the input, and the charger IC is also normal. There is 3.3V at the PS_ID and I have already tested it with another adapter, also original. The adapter detector also seems to work normally. I am suspecting the SIO. What do you think?
                                            On my portable oscilloscope there is a PS_ID signal....
                                            01-02-2025, 02:02 PM
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                          • Johndill
                                            Dell Inspiron 7567 LA-D993P odd charger issue
                                            by Johndill
                                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                            Here are the tested scenarios:
                                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                                            11-16-2022, 10:55 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • PowerAmpFreak
                                            Dell Latitude 7280 does not recognize charger
                                            by PowerAmpFreak
                                            I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                                            Any common faults that could be fixed?
                                            I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                                            How does the communication between the charger and the PC work?...
                                            07-28-2025, 07:18 AM
