Need close-up image of ASUS X442U Motherboard
  • honestmstk
    • Apr 2020
    • 10
    • California
    Hi guys, i bought a broken asus x442u laptop to try and fix. The power light would blink once and the chipset (die next to the i7 processor) would get hot momentarily, if i kept disconnecting and reconnecting the charger it would get reeeally hot.
    Anyways, i narrowed it down to two mosfets that had shorts. Because i didnt have the same ones to replace, i used some similar looking ones. After those were installed, it didnt give any signs. I then realised it had the exact same two mosfets feeding the GPU. I probablyy should have tried those first, but again no signs of life.
    I thought it would at least get further into booting since it didnt really need the gpu for that. Then i noticed that i knocked off a resistor above the mosfet, but i didnt know where it goes since there were multiple empty pads. I also might have knocked a few capacitors while replacing the mosfets. So now i need pictures of that part of the motherboard to see whats missing, but i cant find any close ups online. Or maybe by me using the wrong mosfets at first i killed the whole thing. Idk, but pictures would be nice as it is only one or two components that need touching up, and this board has some nice specs (i7 8550u).
    And let this be a lesson, always take pictures before messing with anything.
    Thank you in advance.
  • kodox
    • Jul 2017
    • 328
    • Indonesia
    Re: Need close-up image of ASUS X442U Motherboard
    have you found detailed picture?
    if u haven't, what the silkscreened model number on the motherboard?
    • honestmstk
      • Apr 2020
      • 10
      • California
      Im still searching, the numbers are:
      PN:60NB0IC0-MB2100 (200)X442UF 16576881
      PT:N0CV1803MB0092425 69N!4RM11A00(01)
      Thank you for your interest and help .
      • mielta
        • Apr 2015
        • 368
        Hi
        Search in Forum for X442 and you will find Boardview . I think that can Help
        • kodox
          • Jul 2017
          • 328
          • Indonesia
          not the sticker on the motherboard.
          the text printed on motherboard with white color.
          ex. X441LJ Rev.2.1
          if you found it, search on schematic section for that board
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
          • MakNCheese
            ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
            by MakNCheese
            I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
            Symptoms:
            • Severe lag across the system, including BIOS navigation.
            • Slow boot times and unresponsive performance in Windows.
            • Battery charges very slowly (e.g., ~5% in 2–3 hours).
            • No error messages or BSODs, just extreme sluggishness.
            What I've Tried:
            • Replaced
            06-04-2025, 12:48 AM
          • andrhouseolly
            Lenovo X240 - motherboard replacement for X250, no image.
            by andrhouseolly
            Friends. I beg you to help me in this situation.
            Lenovo X240 with a video problem. Native Intel drivers are not installed,
            after installation, a black screen. It works with the standard Microsoft driver.
            Understanding that there are problems with the video core,
            I ordered a motherboard from Lenovo X250.
            The laptop turns on, starts up, there is no image on the internal display.
            The image is output to the external monitor.
            I ordered another motherboard from Lenovo X250.
            07-12-2024, 03:02 PM
          • EvazX
            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
            by EvazX
            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
            However, after some time, the replacement motherboard...
            08-25-2025, 06:09 PM
