Lenovo S145-15IWL nm-c121 black screen
    Re: Lenovo S145-15IWL nm-c121 black screen
    if i understand pin15-16 jumper, u3301 remove and in out jumper, r3314 0ohm resistor jumper ?
      Only U3301 remove and IN-OUT pins jumper/R3314 put 0 Ohms. No need to jumper pin15-16. You have voltage on pin15 but missing voltage on pin16. Putting 0 Ohms resistor at R3314 will provide voltage to pin16. So no need to jumper pin15-16. If you jumper pin15-16, then dont put R3314 resistor.
        I did it but no change!
        But now I see that I no longer have 3v on pin15
          Remove R3314 and check again voltage on pin15 is avlbl or not?? If voltage avlbl on pin15, just jumper pin15-16 and dont put R3314.
            I don't understand, it became short-circuited after bios update
            it doesn't turn on anymore
            update: short circuit resolved, I will continue working
              now there is backlight but still no graphics
                I've no more ideas. Its soc fault which I tried to bypass but in the end got backlit only. Sorry bro but I can't help further. May be others can chip in
                  Thank you very much for your help, I am grateful!
                    Originally posted by Jokerx84 View Post
                    Hello!
                    I would like help with a Lenovo S145-15IWL nm-c121 motherboard, there is no picture on the display, but there is hdmi!
                    With display, lvds no problem!
                    The lid has been hit hard, it hasn't worked since!
                    hi, whats the boardview file password plz
                      Thanks.
                        Hello!
                        Thank you.
