Lenovo S145-15IWL nm-c121 black screen
  • Jokerx84
    • Sep 2017
    • 52
    • Hungary
    Hello!
    I would like help with a Lenovo S145-15IWL nm-c121 motherboard, there is no picture on the display, but there is hdmi!
    With display, lvds no problem!
    The lid has been hit hard, it hasn't worked since!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo S145-15IWL nm-c121 black screen
    Do you mean display via hdmi on external monitor is ok but no display on internal screen??
    If yes, is there dimm display on internal screen-means image is there but no backlight??
    Have you tried a known good working screen??
    LID SWitch checked??
    • Jokerx84
      • Sep 2017
      • 52
      • Hungary
      No backlight, no faint image, just black screen, it worked on another laptop!
      I also checked the cover switch, that's good too!
      Sorry for the bad English!
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Measure voltage(JEDP1) on following pins
        Pin 1-2
        Pin 15
        Pin 16
        Voltage on all pins of U3301
        Be careful while measuring on JEDP pins. Your probe should be needle sharp.
        • Jokerx84
          • Sep 2017
          • 52
          • Hungary
          Pin 1-2
          Pin 15
          Pin 16
          pin 1-2=20.1V
          Pin 15=3.3V
          Pin 16= 0V
          U3301
          pin1=0
          pin2=0
          Pin3=0.1
          pin4=0
          Pin5=3.3
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Originally posted by Jokerx84
            pin 1-2=20.1V
            Pin 15=3.3V
            Pin 16= 0V
            U3301
            pin1=0
            pin2=0
            Pin3=0.1
            pin4=0
            Pin5=3.3
            Enable single is missing from PCH to output LCDVDD U3301 pin4 check again
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              As@techtiger has mentioned, you've missing EN signal on pin4. Without this EN signal, you wont get any voltage on pin1. This is a common fault on many mb's. What's the resistance on Pin1 of U3301?? If the resistance is low, remove U3301 and check resistance on pin1 again. If resistance is ok on pin1, then jumper Pin5 to Pin1(U3301 removed).
              Hope this works for you.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Update about the post#7 and then we need to fix missing voltage on PIN16 of JEDP1 as well. Voltage at Pin16 is also a must requirement.
                PS: Probably you wont get display even after taking steps at post#7 but we can still fix it. Just give feedback and follow correctly. If you dont understand what i've said, feel free to write.
                • raajkumar
                  • Mar 2015
                  • 354
                  • Srilanka
                  I had similar issue on same board. I flashed bios with new one. power led is blinking. all other voltages are coming but only cpu_Dramrst is showig 0v.
                  • Jokerx84
                    • Sep 2017
                    • 52
                    • Hungary
                    U3301 pin1=26.1kohm
                    • Jokerx84
                      • Sep 2017
                      • 52
                      • Hungary
                      i flashed more bios and kbc and even kbc was a replacement
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        U3301 pin1=26.1kohm
                        Go ahead and jumper pin5 to pin1(U3301 removed)
                        • Jokerx84
                          • Sep 2017
                          • 52
                          • Hungary
                          jumper, no change
                          • JaroTech
                            • Mar 2015
                            • 351
                            Hi, just to be sure for the lid switch, you have 3.3 volts on pin 3 of U3601.
                            • Jokerx84
                              • Sep 2017
                              • 52
                              • Hungary
                              Originally posted by jarotech
                              hi, just to be sure for the lid switch, you have 3.3 volts on pin 3 of u3601.
                              3.25v
                              • JaroTech
                                • Mar 2015
                                • 351
                                I don't doubt what you said before, it's just that we both check the value of the lid switch the same way.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  jumper, no change
                                  I expected this and have told you so. Now focus on pin16. What is the resistance on pin16?? If resistance is ok then try injecting 3V on pin16 and see if screen glows. If you dont have a dc supply to inject voltage, you can jumper between pin15-16. But before proceeding with either way, do remember to check resistance on pin16.
                                  PS: I had the exact same fault on hp LA-D704 and fixed by removing UG1(Same as U3301 in your case) and jumpering IN-OUT pins and then shorting pin15-16(in my case perhaps pin 23-24)
                                  • Jokerx84
                                    • Sep 2017
                                    • 52
                                    • Hungary
                                    pin16=76kohm
                                    unfortunately i don't have a dc power supply
                                    possibly jumper R3314?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Instead of jumpering R3314, put a 0 Ohms resistor there.
                                      • Jokerx84
                                        • Sep 2017
                                        • 52
                                        • Hungary
                                        I did, no change
