Dead acer 7750g
  • giulio93
    • Aug 2021
    • 258
    • Italy
    #61
    Re: Dead acer 7750g
    Originally posted by mon2
    Read off the laser markings from the top side of the IC. Post the details here.
    I post it in mess #57
    • mon2
      • Dec 2019
      • 14161
      Re: Dead acer 7750g
      This is a SPI flash device.
      So start with the vendor = 'MACRONIX' in the programmer s/w.
      Then look for SPI style -> then the part number showing on the digikey webpage.
      • giulio93
        • Aug 2021
        • 258
        • Italy
        #63
        Re: Dead acer 7750g
        Can I use the bin file on the acer site for the 7750g?
        • giulio93
          • Aug 2021
          • 258
          • Italy
          #64
          Re: Dead acer 7750g
          It's sufficient I make a backup file (read and save in the sw neoprogrammer), so I erese the chip and then I copy the .bin file. Is it correct?
          • mon2
            • Dec 2019
            • 14161
            Re: Dead acer 7750g
            I will suggest to:
            1) make a backup of your current flash chip for safety. do not lose this file.
            2) download the bios file from the Acer website for this model.
            3) erase the chip with your programmer. Confirm that the chip is erased with the programming software.
            4) then flash and verify the flash device with the acer bios image you downloaded from step # 2.
            • giulio93
              • Aug 2021
              • 258
              • Italy
              #66
              Re: Dead acer 7750g
              I will suggest to:
              Ok. I have to use the .bin file, correct? in the folder is present also a .ROM
              • mon2
                • Dec 2019
                • 14161
                Re: Dead acer 7750g
                Post the names and size of each file you are referencing.
                The correct one will match the size of the flash device you are using.
                • giulio93
                  • Aug 2021
                  • 258
                  • Italy
                  #68
                  Re: Dead acer 7750g
                  P5WE0121.bin 4096KB
                  K17C121C.ROM 128KB
                  I don,t understand the last sentence
                  • mon2
                    • Dec 2019
                    • 14161
                    Re: Dead acer 7750g
                    Use this file to reflash your memory device:
                    P5WE0121.bin 4096KB
                    See attached.
                    The density of the flash IC = 4M x 8 = 4096KB (kilobytes) which matches the above .bin file in size.
                    • giulio93
                      • Aug 2021
                      • 258
                      • Italy
                      #70
                      Re: Dead acer 7750g
                      P5WE0121.bin 4096KB
                      See attached.
                      I reprogram the chip succesfully but nothing change. I would like to reprogram the EC chip also. I notice that the one i had bought it's a different model to the original (according to the schematic). Original is MX25L1005 and the one the shop sent me is MX25L1006E. Are they the same? (are they swithcable?). Where can I find a bin file for this chip? Thank you
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        #71
                        Re: Dead acer 7750g
                        Could be the K17C121C.ROM file 128KB taken from the Acer site? (it's in the same folder of the main bios chip)
                        • giulio93
                          • Aug 2021
                          • 258
                          • Italy
                          #72
                          Re: Dead acer 7750g
                          I tried to reprogram the EC chip too with the K17C121C.ROM file ( i do the same procedure used for the .bin, is it correct?) but the result is the same. What do i have to do?
                          the cpu is hot, the fan is spinning but nothing on screen
                          Thank you
                          • bripoll
                            Acer Veriton N4670GT Dead
                            by bripoll
                            Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                            The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                            It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                            I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                            I have programmed it, but it still won't start, it is dead
                            Before programming...
                            11-23-2023, 02:56 PM
                            09-06-2024, 05:27 AM
                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            09-07-2024, 05:00 AM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 04:10 AM
