Hello, I have a MacBook Pro Macbook Pro M1 A2338 820-02020. It got liquid. When I connect the power pack, only 5 volts and 0 amps are displayed! There is nothing to see on the board.
					Macbook pro M1 A2338 820-02020 just 5Volts
 Re: Macbook pro M1 A2338 820-02020 just 5Volts
 Hi. The connector looks good.
 Can you review the cable that is being inserted inside this connector ?
 Are the keyboard cable contacts the proper pitch ?
 What is the logic board 820-xxxx # that has this connector ?Last edited by mon2; 01-31-2022, 10:22 AM.Comment
 https://www.aliexpress.com/item/1005...rch-mainSearch
 Yopolean (Dynamite?) is a good vendor. Have bought from them before a number of times. They have this cable.
 Here are other shops:
 https://www.aliexpress.com/wholesale...psort=1&page=1
 For the connector that is defective - is that on the KEYBOARD or logic board ?
 If on the keyboard, then the keyboard should be replaced.Comment
 Yup, been there and done that. Alternative is to locate a defective keyboard or source a new one to lift off this connector. It will be a bit difficult since these style of connectors warp (melt) very easily.
 I would suggest a blad soldering tip + lots of flux and gently lift one pad off at a time till the connector is lifted. Hot air will warp / melt and kill the connector.Comment
			by OruxHi all,
 I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
 I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
 One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...6 Photos
			by sdogsGreetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
 First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
 I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
			by classicandyHi Everyone,
 Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
 UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless a...
			by User555111Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
- Loading...
