Macbook pro M1 A2338 820-02020 just 5Volts
  • Strolch
    • Nov 2017
    • 245
    • Deutschland
    Hello, I have a MacBook Pro Macbook Pro M1 A2338 820-02020. It got liquid. When I connect the power pack, only 5 volts and 0 amps are displayed! There is nothing to see on the board.
  • mon2
    • Dec 2019
    • 14673
    Re: Macbook pro M1 A2338 820-02020 just 5Volts
    Check and post the voltage on BOTH sides of the fuses:
    FF200
    FF201
    • Strolch
      • Nov 2017
      • 245
      • Deutschland
      Ok, but I have no Boardview just BVR but can not open it. where are the Fuses? thx
      • mon2
        • Dec 2019
        • 14673
        Attached.
        • Strolch
          • Nov 2017
          • 245
          • Deutschland
          thx
          • Strolch
            • Nov 2017
            • 245
            • Deutschland
            all 4 points 5,176Volts
            • Strolch
              • Nov 2017
              • 245
              • Deutschland
              Baby the CD32...
              • Strolch
                • Nov 2017
                • 245
                • Deutschland
                maybe
                • Strolch
                  • Nov 2017
                  • 245
                  • Deutschland
                  I need this connector
                  • mon2
                    • Dec 2019
                    • 14673
                    Hi. The connector looks good.
                    Can you review the cable that is being inserted inside this connector ?
                    Are the keyboard cable contacts the proper pitch ?
                    What is the logic board 820-xxxx # that has this connector ?
                    • Strolch
                      • Nov 2017
                      • 245
                      • Deutschland
                      The cable and the connector are defective! I want to swap the connector on the keyboard but can't find it on the internet!
                      • mon2
                        • Dec 2019
                        • 14673
                        Both are available. Which logic board markings ?
                        Is it for the 820-02020 (A2338) or another ?
                        • Strolch
                          • Nov 2017
                          • 245
                          • Deutschland
                          A1989 emc 3214
                          • mon2
                            • Dec 2019
                            • 14673
                            https://www.aliexpress.com/item/1005...rch-mainSearch
                            Yopolean (Dynamite?) is a good vendor. Have bought from them before a number of times. They have this cable.
                            Here are other shops:
                            https://www.aliexpress.com/wholesale...psort=1&page=1
                            For the connector that is defective - is that on the KEYBOARD or logic board ?
                            If on the keyboard, then the keyboard should be replaced.
                            • Strolch
                              • Nov 2017
                              • 245
                              • Deutschland
                              on the Keyboard. Changing the keyboard isn't that great because of the rivets.
                              • mon2
                                • Dec 2019
                                • 14673
                                Yup, been there and done that. Alternative is to locate a defective keyboard or source a new one to lift off this connector. It will be a bit difficult since these style of connectors warp (melt) very easily.
                                I would suggest a blad soldering tip + lots of flux and gently lift one pad off at a time till the connector is lifted. Hot air will warp / melt and kill the connector.
                                • Strolch
                                  • Nov 2017
                                  • 245
                                  • Deutschland
                                  Yes I know.
                                  I'm trying to get a cheap keyboard.
                                  • 2KGamer
                                    • Sep 2022
                                    • 5
                                    @Strolch, I am seeing the same issue..... Did you find a fix?
                                    • mon2
                                      • Dec 2019
                                      • 14673
                                      If you see 5 volts, then the CD321xx ICs are not working.
                                      Check the LDO rails on each controller first.
                                      • Orux
                                        Macbook Pro M1 A2338 13"
                                        by Orux
                                        I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
                                        I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
                                        One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
                                        09-22-2025, 12:54 PM
                                      • sdogs
                                        macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                                        by sdogs
                                        Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                                        First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                                        I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                                        06-27-2025, 01:58 PM
                                      • sdogs
                                        by sdogs
                                        06-27-2025, 11:26 AM
                                      • classicandy
                                        MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
                                        by classicandy
                                        Hi Everyone,
                                        Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
                                        UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
                                        04-14-2024, 12:00 PM
                                      • User555111
                                        A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                                        by User555111
                                        Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                                        02-05-2024, 08:16 AM
