Dell E5550 LA-A911P R.1 ZAM80 - switch on for a second
  • rbvndonh
    • Mar 2021
    • 162
    • B
    I try to learn laptop repair myself. I have some basic experience.
    Laptop is Dell E5550 LA-A911P R.1 ZAM80.
    Laptop switch on just for a 1-2 seconds and switch off. No self-restarts.
    I can switch on agin, but situation repeat.
    PL101 3.3V
    PL102 5V
    PL700 19.08V
    PL701 13.60V
    On rest coils 0V jumping up just for a while when i push power button.
    I found near pin 4 of PQ200 something like side-melted housing. I found that there is a short between pin 4 and 5 of this chip.
    My plan for tomorrow is to unsolder PQ200 and check also PQ201, because now it also show low resistance.
    How to check if PU200 also need replace and maybe it is no-brainer when PQ200 is faulty, then PU200 also?
    Maybe replace some small resistors/capacitors in it's area also, as i see there is PWR_SRC, so 20V on this line and can go straight on leg PU200?
    Plan for tomorrow also:
    I found some hint to check Measure voltages on pin 2, 4, 7, 8, 11, 12, 13, 18 of PU200 but don't know what values will be proper one?
    2- shall be 0,67V?
    4- VDDR ref. As DDR is 1,35V, so there shall be that voltage?
    7- 0,675V_DDR_VTT - but DDR is 1,35V, so what i shall get here?
    8- _1.35V marked on line
    11-5V
    12- 5V
    13- 1,35V
    18 -1,35V
    Thank you for hints.
  • rbvndonh
    • Mar 2021
    • 162
    • B
    Re: Dell E5550 LA-A911P R.1 ZAM80 - switch on for a second
    No luck. It was just resin on PQ200.
    Any ideas?
    • mon2
      • Dec 2019
      • 14662
      Remove all power. Meter in resistance mode (2k is ok).
      Check each coil on the board for a low resistance value which may indicate a bad cap on that rail which could cause the power supply to shut off as observed. Low resistance = too high of a load and the current sense circuit will trip and disable the switching power supply. Some rails are low voltage and will be with a low resistance but check and post your findings.
      • rbvndonh
        • Mar 2021
        • 162
        • B
        PL101 11,8KR
        PL102 22KR
        PL200 460R (with RAM module) 591R without RAM
        PL301 1,48KR
        PL500 44R
        PL700 40KR
        PL701 3,2KR
        I think that values are quite OK. CPU with 44R i5-5300U is OK?
        Same behavior on AC adapter and battery only.
        PU100 shall be OK, as there is stable 3/5V
        PU200 and PQ200 replaced, however between PQ200 and PQ201 connection there is only 550R to ground.
        PQ200 and PQ100 sometimes show short (after power disconnected) and sometimes not. Like some protection on board is switched on.
        Maybe some PU is malfunction? I hear of some PU700 poor quality soldering. Will look on that tomorrow..
        Edit: pic attached. One pin looks poorly soldered. The solder don't look best on one side of chip. Will resolder it tomorrow.
        • re1nhold
          Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
          by re1nhold
          Hello Guys
          I'm currently fixing two different Dell latitudes,
          I need a E5550 BIOS - SERVICE TAG is: FSFB262
          So far I flashed about 6 BIOS from this forum already,
          none worked,
          only fan spin ~3s, LCD black, keyboard LED on/off ok,
          I tried manual extraction with scripts for ages so to speak. VM is untried yet.
          This laptop is not burnt, it seems to just have a corrupted BIOS.
          I extra baught ram. This has to work friends.
          Do you generate it this way in Windows in CMD?:
          Code:
          E5550A24.exe /writeromfile C:\bios.fd
          07-18-2025, 09:18 AM
        • guruji
          dell e5550 La-A911p ZAM80
          by guruji
          hello
          I have a laptop dell lat E5550 no power ,but I see the stdby 3.3V 5V and 13.70v all okay.I don't get ddr supply no cpu score nor I get 3.3v and 5v S0 voltage.So basically what I understand my micom MEC5085-lzy could be corrupted as RUN_on and SUS_on control voltage is not there.
          anyone programmed this mec5085 chip with svod programmer.it only reads but for write it gives errors.I tried to short #fwp short to ground .but same error.
          pls if some one know how to program
          11-30-2022, 01:14 PM
        • TopPop
          Dell Precision M3800 won't turn on
          by TopPop
          The laptop wouldn't turn on and the charger would shut off as soon as it was plugged in to the laptop suggesting a short on the motherboard some place. I found capacitor PC205 was cracked and shorted. I replaced that. Now the charger doesn't shut off when plugged in to the laptop but the laptop still doesn't turn on. After some more probing I think I found that MOSFET PQ200 is shorted. Seems that the source, drain, and gate are all connected. I did try shorting pins 3 and 4 of the MOSFET which I think is supposed to dissipate any charge that might be in the MOSFET. If there is a charge then the...
          02-18-2023, 08:01 PM
        • lapfix
          Dell Latitude E5550 LA-A911P no complete power on !
          by lapfix
          First the lap come witth a short to GND , it was a faulty capacitator : PC716
          After desoldered , the lap works fine...but after some tries not power on.
          Power supply reach 0.159amp for 1 minute than off...no short to GND at all coils .
          All the voltages at PM TABLE are finded , try another bios same behaviour !
          PS id is oK ; i try with an original charger same behaviour too...
          PQ700 a P-channel is ok , but his gate is not correct..0.001v...
          Pin 5/8 = 19v
          Pin1/3 = 19 v
          Pin 4 = 0.001v...not correct.
          Pu 800 =
          Pin...
          07-29-2024, 06:05 AM
        • orion78fr
          Dell Latitude E5550 LA-A911P rev 1 No Power
          by orion78fr
          I have dell laptop Latitude E5550 LA-A911P that suddenly has no power.
          I haven't found any short on the board (but haven't verified everything so feel free to ask), nothing is getting hot under thermal cam.
          +5V_ALW is present
          +3.3V_ALW is present
          +3.3V_ALW_PCH is absent
          +3.3V_RTC_LDO is present
          +3.3V_M is absent
          +1.05V_M is absent
          A_ON & PCH_ALW_ON are low on UE2 pins.
          PJP15 is 3.3V
          +3.3V_ALW_UE2 is 3.3V
          PCH_ALW_ON should be on no matter what when UE2 is powered right ? Does...
          02-22-2024, 10:06 AM
