dell e5550 La-A911p ZAM80
  • guruji
    • Oct 2012
    • 120
    • India
    hello
    I have a laptop dell lat E5550 no power ,but I see the stdby 3.3V 5V and 13.70v all okay.I don't get ddr supply no cpu score nor I get 3.3v and 5v S0 voltage.So basically what I understand my micom MEC5085-lzy could be corrupted as RUN_on and SUS_on control voltage is not there.
    anyone programmed this mec5085 chip with svod programmer.it only reads but for write it gives errors.I tried to short #fwp short to ground .but same error.
    pls if some one know how to program
  • guruji
    • Oct 2012
    • 120
    • India
    Re: dell e5550 La-A911p ZAM80
    Okay finally programmed it will put the bin file for it but for now uploading the resistor that's need to be shifted for nfwp# 10k to ground.also jtag ret is not necessary to solder but I have market the pad for it .
    • guruji
      • Oct 2012
      • 120
      • India
      tested ec working new version
      • re1nhold
        Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
        by re1nhold
        Hello Guys
        I'm currently fixing two different Dell latitudes,
        I need a E5550 BIOS - SERVICE TAG is: FSFB262
        So far I flashed about 6 BIOS from this forum already,
        none worked,
        only fan spin ~3s, LCD black, keyboard LED on/off ok,
        I tried manual extraction with scripts for ages so to speak. VM is untried yet.
        This laptop is not burnt, it seems to just have a corrupted BIOS.
        I extra baught ram. This has to work friends.
        Do you generate it this way in Windows in CMD?:
        Code:
        E5550A24.exe /writeromfile C:\bios.fd
        07-18-2025, 09:18 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • rbvndonh
        Dell E5550 LA-A911P R.1 ZAM80 - switch on for a second
        by rbvndonh
        I try to learn laptop repair myself. I have some basic experience.
        Laptop is Dell E5550 LA-A911P R.1 ZAM80.
        Laptop switch on just for a 1-2 seconds and switch off. No self-restarts.
        I can switch on agin, but situation repeat.
        PL101 3.3V
        PL102 5V
        PL700 19.08V
        PL701 13.60V
        On rest coils 0V jumping up just for a while when i push power button.
        I found near pin 4 of PQ200 something like side-melted housing. I found that there is a short between pin 4 and 5 of this chip.
        My plan...
        01-11-2022, 03:28 PM
      • Eradicatus
        Dell Latitude E5550 - Strange Internal LCD (BIOS?) Issue
        by Eradicatus
        I have a problem with my Dell Latitude E5550 laptop, in particular with its display.
        This laptop has been sat under my desk (unused) for quite a while and I wanted to reinstall Windows and use it for some ad-hoc testing.
        However, I am struggling with the display, which is playing up.
        1) When the laptop is left switched off, after switching it back on the internal LCD does not work. No images are displayed at all - no DELL logo on POST, no messages, no Windows desktop. But I can hear that Windows starts up correctly, so no issues with the rest of the system - must be...
        04-20-2022, 02:40 AM
      • lapfix
        Dell Latitude E5550 LA-A911P no complete power on !
        by lapfix
        First the lap come witth a short to GND , it was a faulty capacitator : PC716
        After desoldered , the lap works fine...but after some tries not power on.
        Power supply reach 0.159amp for 1 minute than off...no short to GND at all coils .
        All the voltages at PM TABLE are finded , try another bios same behaviour !
        PS id is oK ; i try with an original charger same behaviour too...
        PQ700 a P-channel is ok , but his gate is not correct..0.001v...
        Pin 5/8 = 19v
        Pin1/3 = 19 v
        Pin 4 = 0.001v...not correct.
        Pu 800 =
        Pin...
        07-29-2024, 06:05 AM
