Macbook 820-01700 Stuck at 5V
  • powerblackout
    • Feb 2018
    • 109
    Re: Macbook 820-01700 Stuck at 5V
    ah ok that's a neat idea.
    So remove the resistors R9098, R9598, bridge the two points together for each resistor, then find a 3v3 source and tie it in with each line to force the regulator on?
    Maybe tie it to
    PP3V3_G3H_SSD0_SNS - 3.38v
    PP3V3_G3H_SSD1_SNS - 3.38v
    • mon2
      • Dec 2019
      • 14262
      I believe you noted in this thread that only one of the SSD devices is stuffed ?
      So I would just consider to test perhaps SSD0 if that is what is linked to your SSD that is onboard / module based. No point in hard wiring the other SSD logic if there is nothing onboard.
      Yes, remove the series resistor so that we are not having 2 different driver levels bashing their heads together. Once the series resistor is removed, ok to use the 3v3 rail you have noted onto this ENABLE pin. This is a safe logic / voltage value for this TI device.
      • powerblackout
        • Feb 2018
        • 109
        Sorry if I misspoke before:
        SSD0 has 2 NANDs, SSD1 has 1 NAND. I will need both in order to get DFU to succeed, or does T2 only store partitions on SSD0?
        I got the 2.5V working, do you think the PP0v9_SSD0 and PP1v8_SSD0 lines for the SSD are also required to make it work? those are still 0.0v
        • mon2
          • Dec 2019
          • 14262
          Yes, see your point. Correct that each of these rails are required to power up the SSD. This is now getting sticky.
          The balance of the missing rails are created by U9500.
          Again, the question stands as to why these rails are not being enabled.
          Post the voltage readings for:
          I2C_SSD0_SCL
          I2C_SSD0_SDA
          • powerblackout
            • Feb 2018
            • 109
            I2C_SSD0_SCL - 1.8v
            I2C_SSD0_SDA - 1.8v
            I hooked an oscilloscope up to those lines. Right when I plug the power in I see a bit of communication, not sure if any of the traffic is directed at the U9000/U9500 though
            • bluestone
              • Jun 2011
              • 343
              • Ghana
              #26
              You need to get 2.5v on both SSD1 and SSD0, and yes you need PP1v8 and PP0V9
              • powerblackout
                • Feb 2018
                • 109
                Do you think getting the 1.8 and 0.9 working will also get ocarina working? Is that required also?
                • powerblackout
                  • Feb 2018
                  • 109
                  Thinking about ocarina last night, U9000 has a FORCE_EN that connects to SSD1_OCARINA_FORCE_EN tied to R9011 resistor that attaches to ground. Since SSD1_OCARINA_FORCE_EN doesn't end in a _L that means raising it above 0v would trigger it? If I remove that resistor and attach it to a 1v1 or 3v3 line maybe that will turn it on?
                  EDIT: Actually, looking through this power sequence https://cdn.badcaps-static.com/pdfs/...4429db3748.pdf
                  I am missing P5VG3S_EN, since that is higher up on the power sequence should I try and fix that first? It comes straight from the CALPE-PMU
                  EDIT 2: I found this thread where they are also missing P5VG3S_EN https://www.badcaps.net/forum/showthread.php?t=93596
                  I too am trying to use a USB-A to USB-C coming from a mac mini, perhaps I need to find a macbook with usb-c and try again.
                  • powerblackout
                    • Feb 2018
                    • 109
                    Adding to this evidence, if I plug all 4 usb connectors from the Mac mini to the MacBook about 1 out of 5 times doing the revive I'm able to get the MacBook to go from 12.3v to 12.7v. once in there I can get the MacBook into dfu mode using the keyboard shortcut keys. Maybe plugging it into another MacBook gives it more power to use than a mac mini can provide.
                    • powerblackout
                      • Feb 2018
                      • 109
                      Well that's idea is no longer valid, tried it with a macbook, got the voltage up to 12.7, still no P5VG3S_EN. Recovery still fails. Giving back to customer, can't figure it out
                      • nikey22
                        • Aug 2021
                        • 5
                        PPBUS_G3H should be 12.63V
                        If PPBUS_G3H is 12.32V, T2 chip is stuck in DFU mode.
                        What is your exact PPBUS_G3H reading (to two decimal places please)
                        As usual, @mon2 is spot on, alluding to this pattern in post #9.
                        There is actually no reason to activate the SSD lines at this time because in DFU mode, the data from the host computer is communicated directly into the T2-rom chip (IBridgeOS updates etc..) and doesn't need the use of the NAND at the moment.
                        Looks like you already tested R5220 (PP1V8_SLPS2R - 1.86v) This is the SMC I2C data lines. They seem good.
                        We must determine why the T2 chip is remaining in this state.
                        I need a boardview/.pdf to examine the other culprits like ISL (U7000) and PMU (U7800) in further detail
                        • powerblackout
                          • Feb 2018
                          • 109
                          PPBUS_G3H would start at 12.32, then if I plugged in 3 other usb cords from the mac mini to the macbook i could get it to go to 12.63 1 out of 5 times when trying the revive process. If I only use the one restore cable it would never leave 12.32v and the revive process would fail after a minute. Once in the 12.63V state I could see i2c traffic happening every second with the battery, and the reviving would hang for 12 or so minutes then eventually fail with the error code saying it couldn't find ssd.
                          • Bmet
                            MacBook Pro 13 inch A2238 M2 stuck on 5V
                            by Bmet
                            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                            04-02-2025, 05:02 PM
                          • Steven Pieter
                            Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                            by Steven Pieter
                            hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                            11-24-2024, 10:02 AM
                          • DATATECH85
                            Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                            by DATATECH85
                            I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                            The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                            I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                            However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                            Here are the values...
                            07-24-2024, 06:34 AM
                          • martyjelen
                            Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
                            by martyjelen
                            Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
                            PP3v3_G3H_RTC_X is present - 3,3V
                            PP3v3_G3H_SOCPMU is present - 3,3V
                            ​What else should I check?
                            Thank you for your help.
                            05-05-2025, 01:34 AM
                          • duwane
                            MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                            by duwane
                            Hi All.
                            I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                            Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                            After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                            Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                            10-17-2023, 07:48 PM
