Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
  • Steven Pieter
    • May 2024
    • 11
    • Indonesia
    hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
  • mon2
    • 14677
    Check the voltage to ground on a few areas:
    SMBUS_SMC_5_G3_SDA @ J6951 ; must be ~3v42
    SMBUS_SMC_5_G3_SCL @ J6951 ; must be ~3v42
    - if either of the above are 0v or must lower than 3v42, check if the 3v42 rail is present - if yes, then most likely the TVS diode @ D6950 has triggered and is now shunting this required SMBUS pair of lines. Flux and remove D6950 off the board to remove this shorted component. Test again.
    PPBUS_G3H @ F7000 (check both sides)
    PPVIN_G3H_P3V3G3H @ D6902, pin 3
    PP3V3_G3H @ R6915
    Often, not having 20V is due to the ACE (power delivery) controllers that are onboard.
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    Also,
    https://repair.wiki/w/MacBook_Pro_A1..._of_20V_repair
    • Steven Pieter
      • May 2024
      • 11
      • Indonesia
      Thank you for replying this are the following results I got after analyzing the voltage
      SMBUS_SMC_5_G3_SDA 3v27 not stable sometime jump to 3v41 and 2v66
      SMBUS_SMC_5_G3_SCL 3v29 not stable jump to 3v41 and drop to 2v79
      PPBUS_G3H F7000 both side 0v54 on pin 1 and 2
      PPVIN_G3H_P3V3G3H 4v8 sometime jump to 4v9 and drop to 3v8
      PP3V3_G3H both pin 1 and 2 have 3v42
      • mon2
        • 14677
        Flux and remove the fuse at F7000​.
        Then power up again. Test the voltage to ground on each side of the removed fuse at the pcb pads.
        Is the ppbus_g3h voltage on the producer (isl) side stable?
        Remove all power. Meter in resistance mode. Measure the resistance to ground on the consumer (downstream) side of the removed fuse.
        What is the resistance in ohms?
        • Steven Pieter
          • May 2024
          • 11
          • Indonesia
          Thank you for replying one again
          yes the voltage on ppbus_g3h​ is stable at 3v42
          check the voltage on the fuse F7000 pin 2 0v29 and pin 1 0v042
          after that i checked the resistance on each side of F7000 pin 2 have 5.86K and its not stable it keep jumping up sometime it reach 1.000K . Pin 1 have 0.642 milihohm and it have same condition like pin number 2 (not stable)
          • mon2
            • 14677
            The voltage to power the board travels from the adapter through PPVIN_G3H_P3V3G3H, then the isl regulator will ether buck (lower) or boost the input voltage. Currently not doing either.
            The PPVIN_G3H_P3V3G3H​ rail should be stable.
            Are you using the official power adapter for this logo board? If not, do you have a 100w rated power adapter for usb c?
            The replacement ace controller is under suspicion.
            Review the CD3215 thread linked in the first reply. It is practical to study each step of the 20v selection process.
            The cd3215 should not be hot but each ldo power rail must be present. If you have a voltage that is present and then dips to zero volts then repeats, this is power cycling.
            From where was the cd3215 sourced? What is the full part number of the original and the replacement?
            • Steven Pieter
              • May 2024
              • 11
              • Indonesia
              yes i do have the official power adaptor after some inspection i do notice the cd3215 ic on the left side board (UB400 & U3100) have missing PP1V1_UPC_XB_LDO_BMC on the current active port, and the usb tester keep boot looping on that side.
              • mon2
                • 14677
                Ok - double check your soldering. If necessary - replace this controller. Be sure to replace with a compatible one. Do not throw out the original controller - in case we can reball it for future. This one (non-working) controller can halt your boot cycle.
                • BMCappelletti
                  MacBook Pro A1706 - Stuck at 5V and 0.09A
                  by BMCappelletti
                  Hi everyone.
                  MacBook Pro, model A1706, EMC 3071. Charger shows only 5V and only 0.09A drawn. Board is 820-0239-A. Mint condition. Pretty sure no one ever opened it and was not used much.
                  I tested all steps from the table here https://logi.wiki/index.php/CD3215_Bootup_Sequence changing the CD3215 lines as I moved from one USB-C to the other.
                  What I found was:
                  - on step 3, I have the voltages as 10V and 7.8V, indicated as "Air" on this table, which I suppose would be for a MacBook Air. But this one is a Pro. Same on all DC3215s.
                  - on step 11, on diode mode,...
                  02-10-2024, 02:07 PM
                • pluggedDan
                  MacBook Pro A1706 charge stuck at 5v when battery is plugged in
                  by pluggedDan
                  I have an A1706 that was liquid damaged, the logic board turns on and works when the battery connector is not plugged in, but when the battery is plugged in, the computer is stuck on 5v @ 30-40 Mah, and USB-C meter will reboot every 5 sec or so, pressing and holding down the power button will make the USB-C meter to stop boot looping, and if you keep holding it, fan will quickly spin up and turn off.
                  when the battery is unplugged and plug in the charger then plug in the battery it will stay on 20V and 1.6A-2.6A but when you unplug the charger, the computer...
                  10-29-2023, 02:41 PM
                • Bmet
                  MacBook Pro 13 inch A2238 M2 stuck on 5V
                  by Bmet
                  I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                  04-02-2025, 05:02 PM
                • modtool
                  Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
                  by modtool
                  Dear friends,
                  a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
                  I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
                  I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
                  Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
                  10-25-2025, 05:09 AM
                • MyronViegas
                  MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                  by MyronViegas
                  Hey guys,
                  I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                  Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                  10-06-2025, 08:45 AM
