Macbook Pro 13" 820-3115-B (help for LVDS line components)
  • mon2
    • Dec 2019
    • 14261
    Re: Macbook Pro 13" 820-3115-B (help for LVDS line components)
    Your wifi connection may be weak. Do you have a USB ethernet dongle ? Consider a wired connection if possible and attempt it again.
    https://discussions.apple.com/thread/251479828
    • poldo
      • Mar 2020
      • 33
      • italia
      Originally posted by poldo
      sorgente (1-2-3) = 12,31V
      gate (4) = 12,28V
      drain (5-6-7-8) = 0,132V
      With these values I think the battery should charge, or am I wrong?
      • mon2
        • Dec 2019
        • 14261
        No. Q7055 = AON6403L (see attached datasheet).
        This is an Enhancement type P-channel mosfet.
        To turn this mosfet ON, the gate has to be a more negative voltage than the voltage you wish to pass.
        In your case, the source = gate voltage so the mosfet remains OFF.
        When the gate voltage is lower by xx volts (see datasheet) than the source, then the mosfet will turn ON and pass this voltage onto the battery.
        Reference:
        http://www.learningaboutelectronics....ion%20(VG%20DS).
        Remove all power. Meter in resistance mode (2k scale is ok).
        Check the resistance for the following:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post your measurements.
        • microwave
          • Jan 2022
          • 12
          • Ireland
          Hi are you using the a1278 J30 Schematic ?.
          I also have a a1278 820-3115B board which I purchased with liquid damage but having problems with the trackpad, when I opened the computer up it looks like either a lot of components were removed or maybe never installed on this model, the seller says no work was done to it other than corrosion, the pads look like they were never touched.
          Im just wondering if there is another schematic for the a1278 820-3115B.
          All I can find is a schematic with J30 in the name, no idea where the J30 comes from.
          • mon2
            • Dec 2019
            • 14261
            I have the attached from my paid database.
            • microwave
              • Jan 2022
              • 12
              • Ireland
              #26
              Hi thanks for the fast reply, I have no problem paying for the schematic. the problem is I have other a1278 820-3115B schematics but some say J30 in title and other don't until you open the schematic.
              Im just wondering is there different models of the a1278 820-3115B, probably unlikely.
              Suppose what I really need is good photos of each side of the board.
              Its weird I must be missing not far off ten components and the only thing that's not working is the trackpad. Just feels like I have the wrong schematic.
              Thanks again, I will open a new post.
              • poldo
                • Mar 2020
                • 33
                • italia
                #27
                Reference:
                source (1-2-3) & drain (5-6-7-8) = S+ and D- = O.L
                source (1-2-3) & gate (4) = S+ and G- = 06,37MΩ
                gate (4) & drain (5-6-7-8) = G- and D+ = 07,43MΩ
                • mon2
                  • Dec 2019
                  • 14261
                  The mosfet resistance values look good.
                  • poldo
                    • Mar 2020
                    • 33
                    • italia
                    #29
                    I tried booting with wired connection, it connects but then when the loading apple appears, a few seconds and it turns off.
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      šŸ›  Original Issue
                      āš ļø New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • envym
                      MacBook Pro 2018 with Activation Lock
                      by envym
                      Hi everyone!
                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                      06-27-2025, 08:54 AM
                    • gomonx
                      Macbook Air M1 (820-02016) over voltage 3.2V at line PP1V8_S2
                      by gomonx
                      Macbook Air M1 (820-02016) over voltage 3.2V at line PP1V8_S2 (from PMU BLUK3)
                      I have replaced the ic u8100 but still the same problem. Where should I check next?...
                      06-14-2024, 01:07 AM
                    • tobeend
                      Bypass mdm macbook m2 ventura
                      by tobeend
                      1. RESET MACOS WITH IPSW
                      a. Power off MacBook, press and hold the power button to enter Recovery
                      b. Open Disk Utility, remove Macintosh HD
                      c. Reboot, connect to the network to Activate Mac.
                      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                      e. Release the other keys, but keep holding the Power key for another 10 seconds
                      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                      05-26-2023, 07:18 AM
                    • fricosu007
                      Macbook Pro M1 X A2484 820-02100 short on PPvin_5vusbc23 line
                      by fricosu007
                      Hello friends, today i got an A2485 820-02100-A in a desd state, found visual short on PPVIN_5VUSBC23 line, removed tantalum capacitor, installed same same value from other donor board, now there is no short on any of the rails but when i plug either magsafe3 or usbc inget 5v stable with 0.00 amps drown, no cycle, just these steady values, board is not in dfu mode, checked with magsafe and with usbc. Only value that i find on the board is ppdcin_aon which is 5v… i dont get 3,3 aon, 3v8 aon .. all missing, where should i start looking please !...
                      05-10-2024, 09:40 AM
