Macbook pro a2251 short ssd line
  • som_b1
    • May 2024
    • 21
    • Ukraine
    hello. I'm at a dead end. So, when flashing through dfu, I got an ssd error. I removed all the nand chips and u9000 u9080. As a result, I got 5 volts of consumption and everything is shorting - that is, it seems that all the contacts on the nand chips and yu9000 yu9080 are shorting to each other. Maybe there are a couple of units somewhere that don't short. and I don't know where to look next.
    help
  • fricosu007
    Macbook Pro M1 X A2484 820-02100 short on PPvin_5vusbc23 line
    by fricosu007
    Hello friends, today i got an A2485 820-02100-A in a desd state, found visual short on PPVIN_5VUSBC23 line, removed tantalum capacitor, installed same same value from other donor board, now there is no short on any of the rails but when i plug either magsafe3 or usbc inget 5v stable with 0.00 amps drown, no cycle, just these steady values, board is not in dfu mode, checked with magsafe and with usbc. Only value that i find on the board is ppdcin_aon which is 5v… i dont get 3,3 aon, 3v8 aon .. all missing, where should i start looking please !...
    05-10-2024, 09:40 AM
  • MICHAEL_2013
    Macbook Pro Core I7 A2251 EMC3348 Help Remove MDM
    by MICHAEL_2013
    Good afternoon. My client brought me a Mac A2251 EMC 3348 that he bought at a sale. The computer is completely iCloud-free, but it came with MDM installed. He has tried contacting the company that provides the MDM in every way possible, but they are unwilling to offer a solution. The device is:
    Model A2251 EMC 3348. Serial Number: C02G54CZML85
    Apple MacBook Pro Core i7 2.3, 13" 2020, 512 GB SSD, 16 GB RAM.
    I've tried changing the serial number of the SoC ROM MX25U3235F, but it hasn't worked:
    C02G54CZML84 only works up to Monterey.
    C02G54CZML86 doesn't work (I...
    11-20-2025, 11:18 AM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    šŸ›  Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    āš ļø New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ryancog
    Lenovo Legion 5 Pro 16ARH7H Short On "5V Always-On" Rail
    by ryancog
    Hello there,
    I've got a Lenovo Legion 5 Pro 16ARH7H (AMD Ryzen 7 6800H, NVIDIA RTX 3070Ti) that seems to have "developed" a short on the 5V "Always-On" rail.
    Background
    I don't have too much in the way of useful information here, I don't think. This laptop has been used for the past few years without any notable issues/incidents. The laptop is often "docked" w/ the AC adapter (Lenovo's rectangle one) connected. A few days ago, I finished up working on things in the evening, and the next morning I found the laptop off w/o any...
    04-20-2026, 10:50 PM
  • Jazdzor
    Asus TUF B360m-E short to ground what is that line?
    by Jazdzor
    Good morning. I deliberately bought a motherboard in unknown condition, hoping it would work, but unfortunately, Murphy's Law worked as usual this time. Asus Tuf B360m-E Gaming motherboard. After connecting the power supply, the component marked B45PO3 lit up like a Christmas star, and the NCT5582D also overheated. After desoldering the B45P03, nothing heats up anymore, but there's a problem with a short to ground on the coil and in the area marked PO3001 on the board. I'm not sure if it's lines 3, 5, or the main power line.
    Could anyone suggest where I should start looking for the cause...
    12-21-2025, 10:03 AM
